pi swap - Mustang Evolution
Old 04-04-2012, 07:30 AM   #1
taylor98gt's Avatar
pi swap
What exactly is the pi swap? And what kind of gains does it give you?
taylor98gt is offline   Reply With Quote
Old 04-04-2012, 09:54 AM   #2
Dylanbest's Avatar
I've been wondering about this myself so far what I've figured out that performance improvement is what pi stands for
Dylanbest is offline   Reply With Quote
Old 04-04-2012, 10:04 AM   #3
Mile high JDF's Avatar
They are the heads off a 99-04 GT. They gain something like 40-60 HP if I remember correctly. They bump up compression from 9:1 on a NPI set up to like 9.5:1.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-04-2012, 10:06 AM   #4
taylor98gt's Avatar
I've heard that's its the 99 and up heads and intake, but if I was gonna go through that trouble id go for the dohc swap.
---------- Post added at 12:06 PM ---------- Previous post was at 12:05 PM ----------
Thanks, how much does that usually run? And do you just have to swap.the heads?
Old 04-04-2012, 10:12 AM   #5
DaBluedude's Avatar
A dohc swap is way more money and requires a lot more work. A pi swap is basically heads and intake manifold. Lots of guys take the opportunity to upgrade cams as well.
2003 Mach 1
Old 04-04-2012, 10:13 AM   #6
A DOHC swap would be awesome.
And it just depends on who's selling them. I believe you do need the intake. I have a 2000 GT so I can't say from experience on anything really.
Old 04-04-2012, 10:43 AM   #7
taylor98gt's Avatar
Thanks, I might try it in a few weeks and see how it works out
Old 04-04-2012, 11:21 AM   #8
Good luck
Old 04-04-2012, 07:36 PM   #9
clark98gt's Avatar
Re: pi swap
I can tell you from experience to research a little bit before you dive in. Right now my car is on hold because I didnt realize when you do the swap you need the heads, cams, intake(tapped for the second coolant sensor), and the heater pipe that runs under the intake for a 99-04. Trust me there isnt any way to make the old one work or use rubber hose. If there was I would be driving my car right now. Dont forget you will need all new head bolts also. All in all its not that bad of a job just make sure to gather everything first. Also I thought it bumped the compression up to 10.5 to 1, I could be wrong on that.
1998 Gt- current progress
Engine back in car some reassembly required
clark98gt is offline   Reply With Quote
Old 04-05-2012, 08:19 AM   #10
taylor98gt's Avatar
Thanks, I'm glad you told me, sorry to hear about your car, hopefully you get it straightened out soon!
pi swap Tyler96gt 1996-2004 Mustang GT 7 04-04-2012 08:31 PM
351w or cleveland swap on 88 fox zeltik 1979-1995 Mustang GT 6 03-31-2012 06:42 PM
Engine swap edponder824 2005-2010 V6 Mustang 3 03-29-2012 10:53 PM
Radiator Swap list runvsofthisbull 1996-2004 Mustang GT 1 03-29-2012 08:47 AM
Swap meet SayNo2Pugs Regional Mustang Discussion 0 03-28-2012 07:54 PM
11:06 AM
