pinion seal - Mustang Evolution
Old 04-04-2012, 07:05 PM   #1
2002Gt's Avatar
pinion seal
Any advise what else I should look for when I change it out? And should I go through the drive shaft or go from the differential cover and remove gears? I think it would be easier to go through the drive shaft though
2002Gt is offline   Reply With Quote
Old 04-05-2012, 07:42 AM   #2
2002VertGT's Avatar
Not understanding what you are wantin to do here....I've never changed gears myself but have watched a lot of videos on it and "gears" can only come out through the differential cover. The pinion bolt has to be removed from the driveshaft side before you can remove the pinion thought the diff opening.
EDIT:
Just re-read and it makes more sense...I still think you need to go through the diff though. Not sure how you would get the seal between the pinion and the fromt of the diff housing with out taking it completely out. Are they flimsy?? So that you could get it through the hole without taking it all out? Will the pinion move enough for you to get it in with the gears in?? I think you will have to remove the gears...
4.10 Gear/RPM thread
Old 04-05-2012, 11:42 AM   #3
Mile high JDF's Avatar
You just need to remove the driveshaft. Grab a seal puller (basically just a hook) and pull it out, then hammer in the new one.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-05-2012, 06:21 PM   #4
2002Gt's Avatar
I already have the new one and they are pretty stiff. But I have a guy helping me out now that knows a good bit about rear ends. So I will update whenever I get it done. But anymore advise on this let me know!
70 rack and pinion conversion 1970fbm351 Classic Mustangs 5 02-28-2012 10:09 AM
Rear Main Seal BigB227 1996-2004 Mustang GT 2 02-27-2012 05:27 PM
pinion bearing install Robbie94gt 1979-1995 Mustang GT 6 02-25-2012 12:25 PM
Rear Main Seal? ColeJohnson 1996-2004 Mustang GT 5 02-10-2012 07:39 AM
front main seal FLAT BLACK GT 1979-1995 Mustang GT 4 01-18-2012 02:12 PM
04:40 PM
