aftermarket plugs - Mustang Evolution
Old 04-05-2012, 05:50 AM   #1
imhooked's Avatar
aftermarket plugs
i know ngk iridium ix is popular but was wondering if anyone has used the autolite iridium, or bosch plugs with good results?
imhooked is offline   Reply With Quote
Old 04-05-2012, 06:16 AM   #2
jjsg09's Avatar
If your car is a 99-04 I recommend always using OEM plugs. Don't want to strip the threads in the heads.
Old 04-05-2012, 06:28 AM   #3
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: aftermarket plugs
i used autolites in my V6 no issues at all
SaturnMan8227 is offline   Reply With Quote
Old 04-05-2012, 08:33 AM   #4
use OEM ford copper if thats what came in it, no need to spend more money
Old 04-05-2012, 08:52 AM   #5
Arron's racecar's Avatar
Region: Nevada
Always go with motor craft..
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 04-05-2012, 08:57 AM   #6
McNassty's Avatar
I run NGK laser iridium platinum plugs and love em but the grand total for just the plugs did come to be over $100 and I'm also running with an MSD ignition box and Pro-billet distributer
McNassty is offline   Reply With Quote
Old 04-05-2012, 11:20 AM   #7
Mzilla's Avatar
If you search on line almost every tuner runs NGK plugs on N/A cars and cars with boost. If your has no power adders run NGK tr7. I am supercharged and run around 15lbs of boost and use the TR6 with the gap closed up. I have never had one issue with them. The TR6 are 1 degree cooler and are what they call a V-power plug. Motorcraft stock plugs are decent. AVOID Bosch plugs plugs period. The auto light plugs were decent in the old Fox body pushrod motors.
Mzilla is offline   Reply With Quote
Old 04-07-2012, 07:13 AM   #8
Region: North Dakota
I use NGK Iridium IX's.. guess I'm part of all the rest of the guys out there, but they work very well. I've never had problems with them and run them in multiple vehicles along with MSD coils. I highly recommend them. No need for a racing plug or a "hotter/colder" plug until you actually need it.
K Twisted is offline   Reply With Quote
Old 04-07-2012, 08:12 AM   #9
Dylanbest's Avatar
I Just got a motorcraft plug to throw in when I change the coil on my #4 cylinder. Now that I read this I think I should I've gone with the iridium sounds better but motorcraft should do the trick
Dylanbest is offline   Reply With Quote
Old 04-07-2012, 02:31 PM   #10
imhooked's Avatar
sounds like a toss up!
actually, i did call bama, and the fella i spoke to suggested their tunes might benefit most from plain old (copper) motorcraft/autolite plugs?! kind of surprised me, but hopefully true... could always use the extra scratch for the next mod!
Old 04-08-2012, 10:49 AM   #11
Mzilla's Avatar
Originally Posted by Mzilla
If you search on line almost every tuner runs NGK plugs on N/A cars and cars with boost. If your has no power adders run NGK TR55. I am supercharged and run around 15lbs of boost and use the TR6 with the gap closed up. I have never had one issue with them. The TR6 are 1 step cooler and are what they call a V-power plug. Motorcraft stock plugs are decent. AVOID Bosch plugs plugs period. The auto light plugs were decent in the old Fox body pushrod motors.
Old 04-09-2012, 08:43 AM   #12
imhooked's Avatar
k-t,
tried pm'ing you that i believe i remedied my pinging problem with tuner. did you turn off your pm, or maybe mailbox is full???
anyway, no need to reply the first message i sent requesting the help as i pulled 4 degrees out across the board and problem solved!
Aftermarket head unti help BigB227 Mustang Audio & Video 6 04-05-2012 10:06 PM
best plugs and wires? sixpac 1979-1995 Mustang GT 16 04-05-2012 03:58 AM
Spark plugs? Doe_Rae_mi 1996-2004 Mustang GT 4 03-30-2012 07:47 AM
Aftermarket air filter 2011 GT500 (SVTPP) GT500_CW3 Shelby Mustang 12 03-30-2012 06:00 AM
Spk plugs? 01bullitt 1996-2004 Mustang GT 1 03-28-2012 10:42 AM
11:50 AM
