Suspension - Mustang Evolution
Old 04-05-2012, 07:50 AM   #1
Usikan2237's Avatar
Suspension
What is the best suspension I should get as in ride quality and that lowers it too and what all do I need for a good handling. And how many inches should I drop it here is a pic
Usikan2237 is offline   Reply With Quote
Old 04-05-2012, 07:51 AM   #2
Usikan2237's Avatar
Here is the mustang
Old 04-05-2012, 07:58 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Suspension
In my opinion prolly eibach or maybe vogtland.... i wouldnt go more than 1.5 so u got sum reasonable suspension travel. and be sure which ever brand you get that they are progressive rate springs.... not specific.
hope this helps a bit....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-05-2012, 07:59 AM   #4
Usikan2237's Avatar
What's the difference between them
Old 04-05-2012, 08:09 AM   #5
Titus Wadicus
svtlx's Avatar
Re: Suspension
progressive rate....
will have some travel. or in other words, the springs will compress easier when you go over bumps..somewhat similar to oem springs.. they will give a slightly stiffer ride than oem springs, but still comfortable...
specific rate...
have very lil travel in them.. they are very stiff for all out performance. you get race car like handling all the time, but you also get the race car ride with it. the best i can describe it would be like riding in a mid nineties corvette with bad shocks..lol.
i have specific rate, its super stable at high speeds... but goin over bumps can be a bit jarring at times..
but if u want ride quality..definatley go with progressive rate. you get the lowered look, but with a soft oem quality type ride
Old 04-05-2012, 08:13 AM   #6
Usikan2237's Avatar
That's so helpful so I should lower it 1.5 in the front and 1,75 at the back or 1.5 all around
---------- Post added at 08:13 AM ---------- Previous post was at 08:13 AM ----------
Could you after market springs on stock shocks?
Old 04-05-2012, 08:22 AM   #7
Titus Wadicus
svtlx's Avatar
Re: Suspension
if you do the 1.75 rear... it should level the front with the back. if you do 1.5 all the way around, it will still have the slight rake (back slightly higher than the fronnt) you already have.
just depends on the look u want...
---------- Post added at 08:22 AM ---------- Previous post was at 08:20 AM ----------
yes, you can use the shocks... i would make sure you got sum decent shocks though. i usualy get the "heavy duty" shocks at the parts store... but u could do kyb, or run wut u got till u decide to do a shock swap when funds permit...
Old 04-05-2012, 08:24 AM   #8
Usikan2237's Avatar
How do you tell if the shocks are decent or not
Old 04-05-2012, 08:31 AM   #9
Titus Wadicus
svtlx's Avatar
Re: Suspension
honestly, most ppl dont know/notice their shocks are toast til they are making noise. if you can afford it, i would advise stickn new shocks on it just to be on the safe side, or you can have a shop/mechanic inspect the ones you got...
but new shocks and springs done at same ttime is an awsome ride, and u wont regret spending the money. and maybe an alignment check as well. you will think u got a new car
Old 04-05-2012, 08:43 AM   #10
Usikan2237's Avatar
I looked at some glass d Tokico shocks and tien springs
Old 04-12-2012, 08:05 PM   #11
runvsofthisbull's Avatar
Re: Suspension
Makes sure the tien are not coil over springs because otherwise you will be spending a lot of $ as you need new k member and a arms for coil overs. I used tokico blue/hp shocks which are the same used on Mach 1 and they are pretty nice but not adjustable like the d spec or bilstein. I used steeda comp springs and put some new ball joints too and wow then the car felt like it was on rails. Dropped 1 inch rear and 1.25 front but diff was great to me not too much but enough to notice a huge performance diff. You can see before and after pics under this thread that I made last yr.
Steeds competition springs
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 04-12-2012, 08:11 PM   #12
ColeJohnson's Avatar
I went with H&R SS springs, Steeda bumpsteer and balljoints, Tokico D-spec shocks/struts, and MM C/C plates. My car is a whole new monster now. I rode with all gear above except shocks/struts for a month and the stockers were toast. Night and day difference in ride quality between stock GT shocks/struts and the d-specs.
Dropped about 2" rear and 1.75" front.
2016 Comp Orange GT (current)
Old 04-12-2012, 09:15 PM   #13
2002VertGT's Avatar
Cole u got LT's? That's the same setup I'm after and need to know of LT's will scrape on it...
4.10 Gear/RPM thread
Old 04-12-2012, 09:24 PM   #14
Re: Suspension
LTs will not survive a setup like mine if you DD it on bad roads. I scrape a lot. Coming in and out of businesses, driveways, any type of speedbump.. Lol.
Old 04-12-2012, 10:02 PM   #15
2002VertGT's Avatar
What headers you run??
Old 04-12-2012, 10:05 PM   #16
Stock headers. Lol. My xpipe scrapes and it's as low as LTs would be.
suspension and handling Mr. SoloDolo 2005-2010 V6 Mustang 3 03-29-2012 12:09 PM
Suspension question RVAStang05 2005-2010 Mustang GT 3 03-27-2012 01:50 PM
Suspension Uprgrades? mchilliard28 Pre-2005 V6 Mustang 3 03-23-2012 10:20 PM
Suspension StangRebel 2005-2010 V6 Mustang 11 03-23-2012 12:28 PM
Suspension ? jjsg09 1996-2004 Mustang GT 2 03-19-2012 05:21 PM
01:58 PM
