SCT tuner - Mustang Evolution
Old 04-05-2012, 10:03 AM   #1
StackeStang's Avatar
SCT tuner
I have an automatic 04 GT and the SCT tuner. My car tops out at 125-130, and was wondering if i could change that with my tuner?
StackeStang is offline   Reply With Quote
Old 04-05-2012, 04:39 PM   #2
imhooked's Avatar
Re: SCT tuner
if you're talking top speed limited by governor, then yes you can change it. it's an option within the tune, which you can change yourself
imhooked is offline   Reply With Quote
Old 04-05-2012, 04:44 PM   #3
Don't see much of a need to change the top end
Unless you plan on getting that ride impounded !! Just a thought man
SNK3BTE04 is offline   Reply With Quote
Old 04-05-2012, 06:38 PM   #4
How do I do it?
Old 04-06-2012, 04:01 AM   #5
imhooked's Avatar
Re: SCT tuner
if you go to program vehicle, custom tunes, select which octane tune you want to use and adjust settings. IMPORTANT: it is easy to accidentally change something you don't intend to, so you should scroll down and see which setting is selected (has the checkmarK) first, before entering ''select". it is confusing, 'cause select is the go back button, but really what you want to do is "cancel" if you do not want to change that parameter.
if you have computer, you can make these changes first on your handheld before actually going out and dropping the downloaded into your cars ecu, and i would recommend checking, then DOUBLE CHECKING, that you have not changed anything else.
if you need help i'd be happy to walk you through it later, just let me know and i'll send you my cell
Old 04-06-2012, 11:59 AM   #6
Re: SCT tuner
thanks, i'll give it a try. right now I'm beginning a 5 page paper due by midnight for my Criminal Justice class lol
Old 04-10-2012, 10:09 PM   #7
Re: SCT tuner
checked it out, and the speed and rev limiters are turned off, but my car tops out at 130? its gotta have more power than that with a CAI and tuner
Old 04-10-2012, 10:17 PM   #8
Eturner's Avatar
Something else has to be off then!.. Unless your running some really low gears!..
Old 04-10-2012, 10:29 PM   #9
Stock as far as I know
Old 04-11-2012, 12:59 AM   #10
Jord05's Avatar
Don't wanna steal this thread or anything but just wondering if any one knows how to set up launch controle on a sct tuner thanks!
Jord05 is offline   Reply With Quote
Old 04-11-2012, 01:25 AM   #11
DaBluedude's Avatar
No, 130 is probably all you've got...
2003 Mach 1
Old 04-11-2012, 01:43 AM   #12
Eturner's Avatar
I've hit 140mph once in my '04 GT!.. And that's with just a CAI, tune, and O/R X-pipe!... And with my wife and about 100 lbs of her crap in the car too!... My car is also an auto!..
Old 04-11-2012, 01:49 AM   #13
DaBluedude's Avatar
Vert too??
2003 Mach 1
Old 04-11-2012, 01:53 AM   #14
Eturner's Avatar
Vert too??
Ah!... My car is in my avatar....... Lol But to answer your question it is a hardtop!..
Old 04-11-2012, 05:05 AM   #15
DaBluedude's Avatar
There's the difference. Altitude also makes a difference too. The vert is a lot less aerodynamic.
2003 Mach 1
Old 04-11-2012, 05:09 AM   #16
Eturner's Avatar
A buddy of mine has an '03 Vert GT with similar mods and did 140 also!.... Lol.
Old 04-11-2012, 06:24 AM   #17
DaBluedude's Avatar
cool story bro... The only data I found on top speed is for the coupe, 141. 130 indicated in the vert is about right. The worse aero and speedo error can account for the discrepancy easily.
2003 Mach 1
Old 04-11-2012, 07:00 AM   #18
Eturner's Avatar
Both of our cars have tunes in them!.. Both speedos read accurately!.. Don't know why you find it hard to believe!.. Got another buddy with a Built Vert had his up to 150+!!....
Old 04-11-2012, 07:32 AM   #19
He said 130 stock, so yeah mods will make it go faster. Maybe I'll run it again and see
Old 04-11-2012, 12:49 PM   #20
DaBluedude's Avatar
A built car is a lot different. Mustang speedos have varying levels of error. I find out hard to believe because that's what the physics and specs say. Do the run, have fun, but I don't think there is anything wrong with the car if it peaks at 130...
2003 Mach 1
Old 04-11-2012, 01:33 PM   #21
2002VertGT's Avatar
I've hit 145 in my vert...stock....not sure of altitude...I'm in Ohio
4.10 Gear/RPM thread
Old 04-11-2012, 03:06 PM   #22
I'm in alabama
Old 04-11-2012, 04:11 PM   #23
taylor98gt's Avatar
My friend has a stock 99 vert and his has been 145 and still pulls.
taylor98gt is offline   Reply With Quote
Old 04-11-2012, 04:42 PM   #24
2002VertGT's Avatar
I just tested my claim in a safe area....I got to 130 and hit a small bump and the car started bouncing so I pulled out of it, however I was just starting my pull in 4th gear and was at 130@~3500rpm....
Old 04-11-2012, 04:51 PM   #25
So mine should easily exceed 130 but doesnt
Old 04-11-2012, 04:58 PM   #26
2002VertGT's Avatar
Has to be governed
Old 04-11-2012, 05:23 PM   #27
Re: SCT tuner
I've checked, the speed limiter and rev limiter are both off
Old 04-11-2012, 06:38 PM   #28
taylor98gt's Avatar
Yeah its a pretty scary ride on stock suspension that fast lol
Old 04-11-2012, 06:40 PM   #29
2002VertGT's Avatar
Yeah I just forgot about that small bump...other than that the spot is pretty flat...
New tuner! Ryan7racin 1996-2004 Mustang GT 48 04-11-2012 08:42 PM
sct taylor98gt 1996-2004 Mustang GT 3 04-05-2012 08:53 AM
Problems with livelink and sct x3 btlefed 2011-2014 Mustang GT 5 04-03-2012 01:57 PM
FS: SCT XCAL3, and 3.8 lower and upper intake! SerbStang Mustang Parts for Sale and Wanted 6 04-02-2012 10:11 AM
help with SCT tuner imhooked 1996-2004 Mustang GT 0 04-01-2012 03:21 PM
12:13 PM
