Funny noise when i start engine - Mustang Evolution
Old 04-05-2012, 08:44 PM   #1
Csnow99gt's Avatar
WHen my engine is cold and I start it up it makes a loud rattling noise, is this a lifter sticking or what else could be going on? If so how can I fix this
Csnow99gt is offline   Reply With Quote
Old 04-05-2012, 09:14 PM   #2
MustangGT02's Avatar
Re: Funny noise when i start engine
Mine does it too but after it is ran about 2 min its all gone. idk what it is.
MustangGT02 is offline   Reply With Quote
Old 04-05-2012, 09:17 PM   #3
Csnow99gt's Avatar
Yes it does go away but seems to be getting a little longer before it goes away
Old 04-05-2012, 09:27 PM   #4
Idk it must be something common on 2vs cause my old truck did it too
Old 04-06-2012, 11:06 AM   #5
Csnow99gt's Avatar
Ya it just started last month or so and I cannot stand it, i really want it to go away any help would be greatly appreciated!!
Old 04-06-2012, 11:23 AM   #6
86 muscle's Avatar
Its because the oil hasn't gotten up there yet, that's the reason you don't get on it right away, you let it warm up.
86 muscle is offline   Reply With Quote
Old 04-06-2012, 11:52 PM   #7
Csnow99gt's Avatar
Can that hurt my engine, and how the heck do I get it to stop
Old 04-07-2012, 12:28 AM   #8
86 muscle's Avatar
I don't think so, most cars do it just check your oil, and as for stopping it goes there isn't really to much you can do
Old 04-07-2012, 10:11 PM   #9
silvr002001's Avatar
Yup mine does it 2. Most likely normal
silvr002001 is offline   Reply With Quote
Old 04-08-2012, 01:17 AM   #10
Csnow99gt's Avatar
Man there's got to be some way to stop this, it sounds like ****, pretty ghetto!
Old 04-08-2012, 05:55 AM   #11
deadsp0t's Avatar
Cam followers I believe, OHC engines do not have lifters, because they have no push rods to lift.
That's unimpressive
Old 04-08-2012, 09:32 AM   #12
TXzMAN's Avatar
What kind of oil and filter r u using???
TXzMAN is offline   Reply With Quote
Old 04-08-2012, 09:43 AM   #13
Csnow99gt's Avatar
I have a k&n oil filter and 5w30 synthetic mobile one oil
Old 04-08-2012, 12:29 PM   #14
My 4v 04 Cobra does it also. It only does it the next day when the car sat all night. Yes, this is why you never jump right in the car an go because the oil is completely drained to the pan. I'm assuming it's pretty normal for these cara cause my other mustang did the same crap.
SNK3BTE04 is offline   Reply With Quote
Old 04-08-2012, 12:43 PM   #15
BaSohol's Avatar
Running a good oil filter with the anti drain back valve helps a lot
2007 Ford Mustang GT 5spd
Old 04-08-2012, 12:46 PM   #16
deadsp0t's Avatar
The 4.6 and 5.4 trucks vans and suv's all do it. My 4.0 ranger did it as well.
That's unimpressive
Old 04-08-2012, 12:57 PM   #17
Mile high JDF's Avatar
It's because the engine is starting up without oil pressure. It's nothing to worry about unless it continues for an extended amount of time. As soon as it goes away, that means it has full oil pressure.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-08-2012, 08:14 PM   #18
Csnow99gt's Avatar
How long is an extended amount if time, cause it seems to be getting longer. Could this mean the oil pump is worn or going out?
---------- Post added at 09:14 PM ---------- Previous post was at 09:13 PM ----------
What is anti drain back valve and Which brands have this?
Old 04-08-2012, 08:24 PM   #19
No morw by than a couple seconds. If I'm understanding your problem correctly. I hoinestly. Don't know what that means though, thatsjust wht I've experienced.
Old 04-08-2012, 08:37 PM   #20
Csnow99gt's Avatar
I would say its more like a couple of minutes, I changed oil and filter today, and seem to help a little but didn't fix it
Old 04-08-2012, 09:05 PM   #21
---------- Post added at 03:05 AM ---------- Previous post was at 03:00 AM ----------
Whoops, ok after reading it again, its just a different noise I'm thinking of. I would agree that its just the valvetrain ticking. An anti-drainback valve is a valve that doesnt let all of the oil drain back down to the oil pan. Idk what brands carry them though.
Old 04-11-2012, 07:49 PM   #22
LAS97GT's Avatar
Do cobras have this problem? If they don't, could it be attributed to the oil cooler the oil filter is connected to? It has a seep hole and a plunger mech. That seems to evens out oil pressure. Any ways, I can now hear an intermittent dull rattling vicinity of the H-balancer. When I change out the seal I'll prob upgrade the oil pick up etc. how am I doin dead spot?
---Las97GT
Old 01-04-2017, 07:51 AM   #23
So I have this rattling on startup like you but it's on every startup warm or cold. I've tried adjusting my Cold Air intake and it does something to reduce the noise but never completely and it's ticking me off.
hbalexh is offline   Reply With Quote
Old 01-07-2017, 02:59 AM   #24
Slater2111's Avatar
The rattling could be this problem. Broken timing chain guides. Mine would rattle pretty good on startup and then stop after a couple seconds.
Sent from my SM-G935T using Mustang Evolution mobile app
ID:	214698   Click image for larger version
Slater2111 is offline   Reply With Quote
Old 07-10-2017, 11:51 AM   #25
jkeaton's Avatar
I'm thinking that's my problem. Mine sounds like small pebbles rattling around. Sometimes it does it for a good while, other times it does not do it at all. Not temperature related. Cannot for the life of my figure out where it's actually coming from. Standing in front of the engine, it sounds like it's in the timing chain area. Standing beside the car it sounds like it's coming from underneath at the clutch area.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 07-10-2017, 12:52 PM   #26
Slater2111's Avatar
If thats the case, now is a great time to do cams since you have it all apart.
86 5 speed vibrates when giving gas at idle lilrafe87 1979-1995 Mustang GT 10 04-20-2012 10:15 AM
Heater Noise? Montie 2005-2010 V6 Mustang 22 04-09-2012 05:59 PM
Idleing when it starts laVey420 1979-1995 Mustang GT 8 04-06-2012 11:05 AM
How to Clean Your Engine Blackedout Mustang Paint, Appearance & Detailing 35 04-04-2012 07:57 PM
Drone noise Rosco SVT Mustang 6 04-04-2012 03:56 PM
04:29 PM
