Help with hid - Mustang Evolution
Old 04-06-2012, 09:42 AM   #1
02PONY's Avatar
Help with hid
Anyone with hids have 1 light brighter than the other I've had this problem since I got them I've changed bulbs and ballast around and also purchased different bulbs and ballast then bought new oem headlight assemblies thinking maybe it was be cause one was smoked darker than the other and still have one brighter than the other any help will be great
02PONY is offline   Reply With Quote
Old 04-06-2012, 10:07 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Help with hid
you can try running the main hot to a relay for both ballast so that they are both pulln from the battery.
the left and right side headlight wiring are slightly different amperages.. basicly, the further from the switch, the more the amperage drops.
typicaly the driver side will be brighter cause its closest to the switch.
if you run both lights off the battery instead of being powered from the headlight wire itself...it should fix the problem...
hope im making sense and this helps...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
does any one with a 1994 or 95 use a tuner? lemons95 Pre-2005 V6 Mustang 8 04-10-2012 01:58 PM
You guys with tuners Kingmidas87 Pre-2005 V6 Mustang 48 04-08-2012 04:32 PM
headers with mid pipe gqsmash 2005-2010 Mustang GT 60 04-07-2012 10:52 PM
major intake help needed. robert3188 1979-1995 Mustang GT 8 04-07-2012 08:00 AM
Aftermarket head unti help BigB227 Mustang Audio & Video 6 04-05-2012 10:06 PM
11:01 PM
