First time at track with bullitt - Mustang Evolution
Old 04-07-2012, 12:51 PM   #1
01bullitt's Avatar
Went to track with the bullitt
Mods are.fipk2 k&n intake x.pipe and 315/35/17 in rear
I went 13.91@ 100.6 2.1 60ft
any advice or mods I should do next my goal is to get around 13.2
01bullitt is offline   Reply With Quote
Old 04-07-2012, 01:10 PM   #2
silvr002001's Avatar
Re: First time at track with bullitt
You can try to get your 60ft down a little.
silvr002001 is offline   Reply With Quote
Old 04-07-2012, 01:22 PM   #3
ksrumbel's Avatar
GEARS!!!!
ksrumbel is offline   Reply With Quote
Old 04-07-2012, 01:26 PM   #4
01bullitt's Avatar
I want to get the 4:10 gears abd sct bama tuner from am and steeda underdrive pullys
Old 04-07-2012, 01:58 PM   #5
ColeJohnson's Avatar
4.10 gears will probably take 0.6 secs off if you can hook up..
2016 Comp Orange GT (current)
Old 04-08-2012, 05:53 PM   #6
not too bad of times, get that 60 down and a tune and gear and you could see low to mid 13's. Im tryin to get some money for a sct tuner on my B.
christommy is offline   Reply With Quote
Old 04-08-2012, 06:04 PM   #7
01bullitt's Avatar
This weekend I'm going to port my intake mani and tb how get lil more flow and power then gears and a tune
Old 04-08-2012, 07:30 PM   #8
jjsg09's Avatar
Drag radials and good suspension should really help. If your spinning through gears that's not helping.how good is your clutch?
Old 04-08-2012, 09:33 PM   #9
get a steeda shifter, better faster shifts,
---------- Post added at 09:33 PM ---------- Previous post was at 09:29 PM ----------
defenetly get a tuner to extend your redline ,stock in the bullitt is at 6300 whit tune its at 6500 ,it help my bullitt a lot, plus pump the highest gas you can get went getting your tuner
robertoortiz85 is offline   Reply With Quote
Old 04-09-2012, 08:01 AM   #10
01bullitt's Avatar
Have cobra clutch and a shortshifter
Really didn't kno the redline was 63oo on tbe bullitt thought it was.5800. That's what I was shifting at
Old 04-09-2012, 08:18 AM   #11
your 60ft isnt horrible, 2.1 is about right on street tires for the car, 2.0 would get you .2 better in the quarter though~ if you can cut it down to 1.8 or so that would be even better of course (every .1 60ft is about .2 quarter mile)
Old 04-09-2012, 08:30 AM   #12
01bullitt's Avatar
I think if I let a.little more air out I can get 2.o 6oft I was at 27psi
Old 04-09-2012, 09:03 AM   #13
jjsg09's Avatar
Oh yea I used to run 20psi on my Hoosier drags helps grip more and on hotter days I went down to 18psi
Old 04-09-2012, 10:29 AM   #14
these bullitts dont really make that much power uptop near the redline. Id stick to where your shifting at now and and just work on them gears and the 60.
Old 04-09-2012, 08:52 PM   #15
now whit the tuner I extended my redline to 6500 and went caching good grip I can pretty much cach 1st at 4500 to 5500 55mph, 2nd at 4800 to 5800 88mph,3rd at 4800 to 6400 125mph,and 4th at 4800 to 6400 139mph,and at highway 5th 4500 to 6400 170mph(that's all it gous to)
Old 04-09-2012, 10:17 PM   #16
what?
Old 04-09-2012, 10:28 PM   #17
Mile high JDF's Avatar
Umm what sort of gears are you running? No gear I know of lasts that long unless you have 2.73s or longer.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-09-2012, 10:52 PM   #18
I don't even know if am on 3:26 ever since I got it I never knew how to find out if previous owner added gears went am in highway at 5th speedometer marks 70 2400 ? what gears would that be,
---------- Post added at 10:52 PM ---------- Previous post was at 10:44 PM ----------
also ligthen up a bit in front, remove a/c, all lines. battery, on back I remove the speaker box from the mach system ect sow helps a bit in launches
Old 04-09-2012, 10:58 PM   #19
The best way to tell is by jacking up the rear end with the car in gear and spinning the tire one full turn. Just count how many times the driveshaft spins. I'd peg you at 4.10s or possibly 4.56.
Old 04-10-2012, 10:18 AM   #20
CodyNelson's Avatar
Region: West Virgina
That would make his top speed in each gear lower than stock... With stock gears I can run 2nd to 65mph, and 3rd to 100. IF this is true he has lower than stock gears
Old 04-10-2012, 10:49 AM   #21
Yeah I realized that. But what hes saying about 2400 in 5th is the part that doesnt add up.
Old 04-10-2012, 03:34 PM   #22
I re-did a run today morning after work in to the freeway from a stop these is what I came up whit , 0 to 60 in 1st at 5900, 60 to 87 in 2nd 6400 ,87 to 119 in 3rd 6400 119 to 135 4th 6400 135 to 150+ 6400, I shifted right before my revlimiter at 6500 to get the most speed
---------- Post added at 03:34 PM ---------- Previous post was at 03:32 PM ----------
my friends dad said it sound like am at 3:55,
Old 04-10-2012, 04:54 PM   #23
I have 3.55s and I don't turn 2400 until I hit around 78mph in 5th. The only problem I'm seeing is that with the speeds you are posting, it just doesn't match up to what gears you think you have. With my 3.55s I'm hitting redline at 5800rpm at 38-39mph. The only way you could possibly hit 60 in first would be if you have an aftermarket transmission with whatever gears you have. Unless you have gears below the 3.0 mark.
Old 04-10-2012, 10:59 PM   #24
I retune my tire size I was running 858revolutions in 275/30/17 that's about 3 to 4 miles more my speedo so really am doin 54 to 55 instead of 60 ,but ill be getting some 275/40 next week that would read 55 goin 54 I check it whit the tire calculator
Old 04-10-2012, 11:02 PM   #25
Ok.
Old 04-11-2012, 08:02 AM   #26
WheelStander's Avatar
Most of these numbers are probably off because hardly anyone's speedo is calibrated.
I know mine is off after swapping to 373 from stock.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 04-11-2012, 10:35 AM   #27
CodyNelson's Avatar
you do not go 60 in first gear. with stock gears and a 5 speed you barely make it to 60 in second gear!!! please quit posting lies
Old 04-11-2012, 05:12 PM   #28
re read it codynelson I recalibrated my tire size?
Old 04-12-2012, 06:11 AM   #29
CodyNelson's Avatar
you still do not do 50-55 in first!
Old 04-12-2012, 07:43 AM   #30
try it before 6500
Old 04-12-2012, 08:12 AM   #31
are you shifting right before you cross the line, if so you may wish to hold each gear a BIT past peak power to offset the need for the extra shift etc~
Old 04-12-2012, 03:10 PM   #32
I shift it in 1st around 6300-6400 to not hit the limiter at 6500, all other gears at 6500 I still get pretty good responds after 6300 sow i give it that little extra rpm to 6500
Old 04-12-2012, 05:42 PM   #33
Idk ro, much respect but this just doesn't add up.
Old 04-13-2012, 07:06 AM   #34
CodyNelson's Avatar
Old 04-13-2012, 09:00 AM   #35
I think his speedo, it has to be wrong.
Load up a Speedo app on your phone and check it against your speedometer that you'll find that it doesn't match up.
does any one with a 1994 or 95 use a tuner? lemons95 Pre-2005 V6 Mustang 8 04-10-2012 01:58 PM
You guys with tuners Kingmidas87 Pre-2005 V6 Mustang 48 04-08-2012 04:32 PM
It's time for the big decision....... l2plagears Pre-2005 V6 Mustang 38 04-07-2012 04:58 PM
Few weeks with my tuner, my current thoughts. Project Pony Pre-2005 V6 Mustang 15 04-06-2012 09:48 PM
Help with RHD convertion on a 67 Coupe Wynand Classic Mustangs 1 04-06-2012 08:58 PM
09:41 AM
