Cams - Mustang Evolution
Old 04-07-2012, 01:58 PM   #1
99redgt's Avatar
Cams
Hey I don't know much about cams but I'm thinking of buying some, I have a 1999 gt with flowmaster, CAI, 4.10 gears, sct chipped, what do you think? I use my car for mostly daily driving
---------- Post added at 02:58 PM ---------- Previous post was at 02:58 PM ----------
Should I put my money into something else?
99redgt is offline   Reply With Quote
Old 04-07-2012, 02:01 PM   #2
ColeJohnson's Avatar
Re: Cams
Cams are rather expensive and are gonna need the use of new beehive springs if you go stage 2+ and also a re-tune. It gets pricey but there is definitely gains to be made if you get a better intake as well.
2016 Comp Orange GT (current)
Old 04-07-2012, 02:08 PM   #3
99redgt's Avatar
I would probably be better off getting headers and a x pipe or something?
---------- Post added at 03:08 PM ---------- Previous post was at 03:08 PM ----------
I just love the sound of cams...
Old 04-07-2012, 08:28 PM   #4
Re: Cams
Headers and an x-pipe are a much cheaper and safer way to get a good sound and honestly you don't even need new headers because stockers have plenty of flow unless you go LTs... And while a cam's lope is sex, basically, it is rather expensive. As all good things are.
Old 04-07-2012, 09:04 PM   #5
Stangnation's Avatar
Re: Cams
I have similar upgrades on my 2004 GT and I was looking into cams as well, and if it were easy everyone would do it. First you'd have to pick a cam, (I'm not saying you have to use Comp, just an example) and then with almost any cam upgrade you would want too change the springs and retainers. Also because yours is a 99 it probably has Windsor heads that have a pressed on cam gear, so you have to get new cam gears too, you can tell what heads you have by how many bolts in the valvecovers; 13/14 = Windsor, 11 = Romeo. Then you have to get it tuned some wheres because if you are like me and bought an SCT tuner from AM, they can't/won't write tunes for it. I spent a while finding all this out so I figured I'd pass it on. If anyone has anything else to add please do, I most likely missed some things.
Stangnation is offline   Reply With Quote
Old 04-07-2012, 09:24 PM   #6
Pretty much summed it up. I was too lazy to write it all up. Lol
Old 04-08-2012, 12:23 AM   #7
99redgt's Avatar
Thanks guys, I'll just look into getting a full exhaust system , by the way has anybody had problems with there headers becoming lose? My mechanic told me just to keep stock manifolds because you will have to keep tightening your headers ??
Old 04-08-2012, 12:31 AM   #8
He's probably talking about the header gasket not being normal with aftermarket headers. Honestly you may have to tighten them once or twice after you install... But they should set rather quickly.
Old 04-08-2012, 05:53 AM   #9
Dylanbest's Avatar
They won't write up a custom tune for cams?
Dylanbest is offline   Reply With Quote
Old 04-08-2012, 11:16 AM   #10
Re: Cams
No, I called them (AM) and they said they don't do it...I was heart broken.
Old 04-08-2012, 12:27 PM   #11
Arron's racecar's Avatar
Region: Nevada
I don't believe you need a tune if you go with a mild street cam
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 04-08-2012, 12:55 PM   #12
Mile high JDF's Avatar
You need a custom tune because of the differences in elevation, the air gets thinner the higher up you go so you need to get a custom dyno tune to compensate for it.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-08-2012, 02:48 PM   #13
Dylanbest's Avatar
Damn
Cams GunMetalBullet 2005-2010 Mustang GT 10 03-19-2012 10:44 AM
Cams ?? Horseplay Pre-2005 V6 Mustang 8 03-18-2012 11:57 PM
Cams AmericanMetal 1996-2004 Mustang GT 58 03-14-2012 06:43 PM
Need cams 1lowGT 1996-2004 Mustang GT 4 03-12-2012 05:09 PM
Thumper cams? Cm644rodrigues 1979-1995 Mustang GT 2 03-11-2012 03:25 PM
11:49 AM
