Clutch help - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 04-08-2012, 07:26 AM   #1
Cantlin01's Avatar
Cantlin01 is unknown around these parts
Clutch help
Hey guys I got an 01 gt looking to get a new clutch soon. Any help on brand I should go with and where I can pick it up.
Cantlin01 is offline
Old 04-08-2012, 07:35 AM   #2
Black Beauty
MiGT01's Avatar
MiGT01 is unknown around these parts
Re: Clutch help
AmericanMuscle.com. RAM HDX is what I have and love it!
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline
Old 04-08-2012, 09:40 AM   #3
Csnow99gt's Avatar
Csnow99gt is unknown around these parts
I had some problems with spec clutches, so I went with a ford racing clutch kit and flywheel, and also bought a the ford racing Throwout bearing which is a lot stronger then the ones that come with the kits, and it has held up great!!! I have herd good things about ram also
Csnow99gt is offline
Old 04-11-2012, 07:53 PM   #4
LAS97GT's Avatar
LAS97GT is unknown around these parts
How many miles have you put on the AR clutch?
---Las97GT
LAS97GT is offline
Old 04-11-2012, 09:35 PM   #5
LAS97GT's Avatar
FR CLUTCH.
---Las97GT
LAS97GT is offline
Old 04-12-2012, 08:07 PM   #6
Csnow99gt's Avatar
I've put around 3000 to 4000 miles since then and no problems
Old 04-16-2012, 08:02 AM   #7
Cantlin01's Avatar
Anyone heard bad things about exedy clutches
Old 04-16-2012, 09:48 AM   #8
t0t4lbl4ck0ut's Avatar
t0t4lbl4ck0ut is unknown around these parts
I've had my spec for around 2000 miles and have had zero problems with it. It grips and grips and the drivability is near stock even with a stage 3+
t0t4lbl4ck0ut is offline
Old 04-19-2012, 11:10 AM   #9
Mmustang01's Avatar
Mmustang01 is unknown around these parts
Go with spec stage 3 is the best way to go for street and track use
Also if u can get a aluminum flywheel the cost for labor will be the same since they have to remove the flywheel in order to install the clutch
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline
Old 04-20-2012, 01:19 AM   #10
JDF
JDF's Avatar
JDF is unknown around these parts
What are your plans for the car? I've said it before on other threads: don't over-clutch your car. It's pointless getting a Stage 3+ clutch when you don't plan on pushing a lot of horsepower. You sacrifice pedal stiffness and potentially drive ability depending on the friction material you choose. If you are never getting above 400-450 ft lbs of torque then look into a stage 1 or 2 clutch. Center force is a pretty good brand, along with Exedy, I've heard both good and bad reviews with Spec. The way I'd go is a Luk clutch. They are THE brand that most manufacturers use and they make a damn good clutch for being stock.
2000 GT-
Engine: K&N cold air intake, Bassani offroad x, Magnaflow catback, Bama 91 octane race tune, 3.55 gears dyno'd at 233whp 272wtq before exhaust
Suspension: IRS swap with stock cut 03 Cobra springs
Brakes: Front and rear brakes from an 03 Cobra with EBC Yellowstuff pads
JDF is offline
Closed Thread
Just bought a gt and need help UltimateGt 1996-2004 Mustang GT 53 04-12-2012 12:59 AM
need help! Robbie94gt 1979-1995 Mustang GT 13 04-08-2012 03:29 PM
Need HELP! Gobabygo67 Mustang Paint, Appearance & Detailing 18 04-08-2012 12:04 AM
Please Help, looking for used hood scoop. Dubya11 Mustang Parts for Sale and Wanted 8 04-07-2012 10:17 PM
major intake help needed. robert3188 1979-1995 Mustang GT 8 04-07-2012 08:00 AM
01:07 AM
