Steeda underdrives pulleys - Mustang Evolution
Old 04-09-2012, 12:01 PM   #1
02utahgt's Avatar
Region: Utah
I was wondering about the gains by using the steeda underdrive pulleys. Are they really worth it? I don't have a big system to draw volts.
02utahgt is offline   Reply With Quote
Old 04-09-2012, 12:06 PM   #2
BaSohol's Avatar
I had a bbk on my old lincoln mark viii and it was a 3 pully kit, it did cause low volts and dim lights at idle, I just took the alt pully off and it was better
2007 Ford Mustang GT 5spd
Old 04-09-2012, 12:11 PM   #3
02utahgt's Avatar
Region: Utah
Any hp gains?
Old 04-09-2012, 12:29 PM   #4
02stangswagg's Avatar
I got steeda under drive pulleys u can feel the difference
02stangswagg is offline   Reply With Quote
Old 04-09-2012, 12:42 PM   #5
jjsg09's Avatar
I got them too. There is a difference in the in acceleration but don't feel it in higher rpms.
Old 04-09-2012, 12:48 PM   #6
02utahgt's Avatar
Region: Utah
Are they worth the cost?
Old 04-09-2012, 01:21 PM   #7
Re: Steeda underdrives pulleys
UD pullies can free 5-10rwhp depends on car~ average is about 6-7 rwhp probably~ with 25% underdrive crank
Old 04-09-2012, 01:41 PM   #8
Not worth the money not the install time. iMO
SNK3BTE04 is offline   Reply With Quote
Old 04-09-2012, 02:01 PM   #9
02utahgt's Avatar
Region: Utah
That's my issue . if I could a set for $50 or so I would do it but I'm kinda thinking to put the $200 toward my gear fund. Thanks for all the input.
Old 04-09-2012, 02:15 PM   #10
I don't really think there worth it and heard a lot of bad things about them
Ryan7racin is offline   Reply With Quote
Old 04-09-2012, 02:50 PM   #11
BaSohol's Avatar
I would get them 6-7 hp might not be a lot but it's a mod motor so nothing is going to give you a lot a power unless you supercharge it or build the motor
Old 04-09-2012, 03:02 PM   #12
BigB227's Avatar
So if you have a system dot get the pullies??
BigB227 is offline   Reply With Quote
Old 04-09-2012, 03:33 PM   #13
2002VertGT's Avatar
Like what??? Tell the bad things you have heard?
---------- Post added at 04:33 PM ---------- Previous post was at 04:32 PM ----------
Just don't use the alt pulley! The only problem with using alt pulley is at idle! If you don't play your system at idle a lot don't worry about it!
4.10 Gear/RPM thread
Old 04-09-2012, 03:40 PM   #14
BaSohol's Avatar
Like I said the only bad thing is the volt output, I had a 160 t-stat so I never noticed my cooling system struggle stayed the same with or without the pullies
Old 04-09-2012, 04:17 PM   #15
What I heard is it shuts off a lot of power like problems with lights, a/c, if you have speakers that sort of thing
Old 04-09-2012, 04:37 PM   #16
2002VertGT's Avatar
@ idle it can IF u use the alt pulley. Or you can put a better alt on it and be fine...I personally bought a used set w/o the alt pulley so I didn't have to worry about it!
Old 04-09-2012, 05:02 PM   #17
A guy I met awhile back said it made his alt go out he took them off and went back stock after I heard that I decided not to get them
Old 04-09-2012, 05:06 PM   #18
McNassty's Avatar
U/D pullies give you better throttle response. I have BBK and like everyone else says just leave the alt. pulley off and you should be fine
McNassty is offline   Reply With Quote
Old 04-09-2012, 05:08 PM   #19
2002VertGT's Avatar
X100
Old 04-09-2012, 05:32 PM   #20
BigB227's Avatar
Thanks for clearing that up man
Old 04-09-2012, 07:00 PM   #21
jjsg09's Avatar
I have the under drive pulleys and I have left the alt pulley on and never have had any power issues. No dimming lights, no sound system issues, or slowing of power anywhere. You need to put on the alt pulley it comes with, it's smaller and helps the alt keep up by spinning faster. I never had an issue or anything wrong with the steeda UD, the only problem I had was the install. To me they are worth it, I felt a definite change in the lower rpms. These really pay off if you do a ac, smog, steering delete, but who wants to really do all that.
06:50 AM
