Is it legal? - Mustang Evolution
Old 04-12-2012, 10:59 AM   #1
BigB227's Avatar
Is it legal?
Is it against the law in Florida to take out the cats?
BigB227 is offline   Reply With Quote
Old 04-12-2012, 11:11 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Is it legal?
im sure its federal law....but dont tell anyone...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-12-2012, 11:15 AM   #3
BigB227's Avatar
Well I know that but I want to put a prochamber in and it's my daily driver
Old 04-12-2012, 11:23 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Is it legal?
you should be ok if they dont enforce it i suppose. every state is different.. i seen a county one time where the sheriff checked for cats... i think you should check with your local enforcement or fhp and see wut they say.
Old 04-12-2012, 11:31 AM   #5
NeedSomeMods's Avatar
I checked my local laws and it states that a car originally equipped with catalytic converters must have them installed and working properly at ALL times. I'm also in an emissions restrictive county.
As svtlx said, check with local laws before making a very costly mistake.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-12-2012, 11:45 AM   #6
BigB227's Avatar
Ok thanks man I will
05:52 AM
