compression ratio - Mustang Evolution
Old 04-12-2012, 08:59 PM   #1
allen1998gt's Avatar
compression ratio
What should my compression ratio be if i.want to supercharge my Mustang GT? And how does one change the compression ratio?
allen1998gt is offline   Reply With Quote
Old 04-12-2012, 10:56 PM   #2
Mile high JDF's Avatar
How much boost do you plan on pushing. People running serious boost usually run around an 8:1 or less ratio. The only ways to change it are new pistons and a larger combustion chamber on your heads.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-13-2012, 12:03 AM   #3
I want 12 to 16 lbs
Old 04-13-2012, 12:19 AM   #4
I want 12 to 16 lbs
You should be able to get away with a 9:1 ratio, however you will need a fully forged bottom end to handle it.
Old 04-13-2012, 01:06 AM   #5
I plan on it. Eh my wallet hurts
Old 04-13-2012, 07:40 AM   #6
CodyNelson's Avatar
Region: West Virgina
Re: compression ratio
9.0 is as low as I would go though. Anything lower than that and you will lose alot of bottom end
Old 04-13-2012, 07:45 AM   #7
boost wont modify the compression ratio. For a 99-04 GT about 450rwhp is the limit, thats about 10-11psi or there about I believe~ any more and you are just asking for issues down the road at some point.
Old 04-13-2012, 07:58 AM   #8
CodyNelson's Avatar
This is true, but he stated that he is getting a forged shortblock and in another thread he also mentioned TFS heads. So between choosing heads and pistons, he has a wide open possiblity for choosing his CR
05:35 AM
