Strange noise - Mustang Evolution
Old 04-14-2012, 05:09 PM   #1
Strange noise
I have a strange nose right below my shifter it sounds like a lose bracket on my x-pipe but I checked them all and none of them are lose does anyone know what this could be?
It sounds just like a lose bracket rattling
Ryan7racin is offline   Reply With Quote
Old 04-14-2012, 07:21 PM   #2
Is it a manual or auto
96gt014.6 is offline   Reply With Quote
Old 04-14-2012, 11:16 PM   #3
Manual
Old 04-15-2012, 03:25 AM   #4
t0t4lbl4ck0ut's Avatar
Check all the bolts on your tranny crossmember. Should be 6 bolts. 2 in the middle and 2 on each side right above the cats I believe. That's where I'd start.
---------- Post added at 09:25 AM ---------- Previous post was at 09:24 AM ----------
I hate trouble shooting
t0t4lbl4ck0ut is offline   Reply With Quote
Old 04-15-2012, 04:00 AM   #5
It's not me, it's you.
primer2tone's Avatar
Could the sound be compared to chains rattling? How's your transmission shifting? I had a similar problem with my old car. It went on for about a year and then my transmission locked up and blew into pieces. Maybe you should change your transmission oil?
Old 04-15-2012, 05:54 AM   #6
vinnygt's Avatar
Would it rattle and shake when u would hit high speeds? Cuz mine doesn't make any noise but it shakes likes crazy when I go fast. Could it just be lose?
vinnygt is offline   Reply With Quote
Old 04-15-2012, 09:47 AM   #7
It maybe a little loose, have you checked all
Your mounts ? Added some trans fluid ?
Old 04-15-2012, 09:48 AM   #8
It just makes noise when from a low rpm start its shifting fine no problems at all just the rattling is kinda getting on my nerves
Old 04-15-2012, 09:50 AM   #9
It may have a loose bolt, because some of those bolts are a pain the rear end to get to or may be a mount, which both could
Make a rattle sound
Old 04-15-2012, 01:04 PM   #10
runvsofthisbull's Avatar
Re: Strange noise
I had a similar issue which started happening after I lowered mine. Turned out it was the speedometer cable rubbing on either the exhaust or something else can't remember exactly but I zip tied and it was fine, but mine was auto too so not sure.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 04-15-2012, 02:23 PM   #11
Thanks for sharing that, it does kind of sound like that it's only from 1,000-2,000 RPM once I get to 4th and 5th it stops all together
Old 04-15-2012, 04:04 PM   #12
vinnygt's Avatar
How can I check my fluid? And no I have to check my mounts still. Just need to find a way to get my damn car up on some ramps lol
Old 04-15-2012, 06:24 PM   #13
Think I found it this washer rattling side by side
ID:	47233   Click image for larger version
04:01 AM
