2003 mustang gt misfire - Mustang Evolution
Old 04-15-2012, 01:51 AM   #1
jordan03's Avatar
I just got a.03 mustang gt automatic and.it is misfiring under a load all the coils are new along with the plugs any answers?
jordan03 is offline   Reply With Quote
Old 04-15-2012, 02:32 AM   #2
Rm360's Avatar
Did you use stock replacement coils or did you go after market?
Old 04-15-2012, 03:18 AM   #3
t0t4lbl4ck0ut's Avatar
Something like this where it can be any number of things it's always best to start at the cheapest angle. I had a similar problem when my o2 sensor went bad. How many miles you have in it?
t0t4lbl4ck0ut is offline   Reply With Quote
Old 04-15-2012, 11:47 AM   #4
jordan03's Avatar
Yes stock coils and 149000
---------- Post added at 12:47 PM ---------- Previous post was at 12:14 PM ----------
The misfiring will change cylinders when u Get it under a load it.never stays in the same cylinder I'm thinking it could be the computer?
Old 04-16-2012, 05:36 PM   #5
Rm360's Avatar
Do you have any codes? When is the last time you changed the fuel filter? A dirty fuel filter will let contaminets get thru to the injectors clogging them up causing a misfire. This may be why the misfire is "jumping" around
Old 04-16-2012, 06:49 PM   #6
jordan03's Avatar
No codes would a code be thrown if.that was the case
Old 04-17-2012, 11:57 AM   #7
A lot of the time I've read that when our cars have a misfiring problem they don't throw codes. If you've changes the plugs and coils the best thing I can suggest is a diagnostic test at a ford garage. It could be a fault in the computer or really anything. Maybe you can't swap the injectors around and see if it's a clogged injector. But outside of that I'm out of ideas
Old 04-17-2012, 12:01 PM   #8
jordan03's Avatar
I took it to a garage and.what do you know.two blown heads
Old 04-17-2012, 12:05 PM   #9
Gobabygo67's Avatar
Gobabygo67 is offline   Reply With Quote
Old 04-17-2012, 12:07 PM   #10
What do you mean blown heads? I guess i don't understand how the head itself can be ruined unless it was cracked.
Old 04-17-2012, 12:18 PM   #11
jordan03's Avatar
Blown head gaskets
Old 04-17-2012, 12:21 PM   #12
Oh ok. The gaskets are blown. That's a fairly cheap fix if you can do the work yourself.
Old 04-17-2012, 12:51 PM   #13
jordan03's Avatar
1900 I cant
2003 mustang
08:07 AM
