suspension questions - Mustang Evolution
Old 04-15-2012, 10:35 PM   #1
taylor98gt's Avatar
i have a 98 gt and the previous owner decided to cheap out when lowering the car and just heated the springs. needless to say it rides like **** now. so my question is, should i just get a complete 98 cobra suspension for it, or go on and go all aftermarket? thanks
taylor98gt is offline   Reply With Quote
Old 04-16-2012, 07:51 AM   #2
Re: suspension questions
go with better springs, H&R or some other progressive rate for sure. If you want a stock like ride (aka wont handle as good) eibach makes a softer progressive rate spring
you will need CC plates for alignment and probably time to replace shocks/struts (mach 1 tokicos work good)
Old 04-16-2012, 10:05 AM   #3
taylor98gt's Avatar
should i go on and try an get control arms and sway bars while i got it apart?
Old 04-16-2012, 10:35 AM   #4
I would look into maximum motorsports lower control arms (spherical bushing, good design) and for the uppers keep factory~ they can cause bind if you go aftermarket. The 98 cobras had stiffer rubber bushings but the upper arm itself is the same so that would work good
the sway bar may be thicker, can check if so get it.
H&R race are the ones I was talking about, my rate is like 760front vs stock 450~
Old 04-16-2012, 10:46 AM   #5
taylor98gt's Avatar
Okay thanks. I'm glad I found this forum lol
Old 04-16-2012, 11:13 AM   #6
with suspension you can go REALLY far or just do a few choice items that really help the overall ride.
If you go to hard core the ride will suffer to much and it will be a horrible ride. You need to decide if you want a good ride or not so good ride but it handles well~ overall it wont be THAT bad if you go with progressive springs and good shocks/struts just an FYI though.
these mods can be done in your driveway with a friends help over a weekend of quicker as well FYI
Old 04-16-2012, 12:13 PM   #7
taylor98gt's Avatar
Here's a picture of my spring
Old 04-16-2012, 12:18 PM   #8
CodyNelson's Avatar
Region: West Virgina
Get that thing out of there now!!
Old 04-16-2012, 12:22 PM   #9
NeedSomeMods's Avatar
Holy crap..
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-16-2012, 12:27 PM   #10
Why do people do dumb **** like that ???? Yeah, get that POS out and put some decent springs in man
SNK3BTE04 is offline   Reply With Quote
Old 04-16-2012, 12:58 PM   #11
I have no idea why anyone would heat up a spring vs just cut a coil off it.... just lazy
Old 04-16-2012, 01:09 PM   #12
taylor98gt's Avatar
I know its stupid, and now my car handels like complete ****. Ima try to get some cobra springs off Craigslist for right now and get all aftermarket later on
Old 04-16-2012, 02:00 PM   #13
try to find ford C springs, they are 600 rate front300 rear, linear but a good sprign for 100 bucks or so. drop is 1.25 or so generally
Old 04-16-2012, 02:38 PM   #14
taylor98gt's Avatar
Where could.I find those?
Old 04-16-2012, 06:05 PM   #15
CodyNelson's Avatar
There is a guy on www.corral.net that has some for sale for 100. His name is 1fast99gt I believe. They are in the classifieds. He even cut the rears to even it out a little more. They look good from the pics.
Old 04-16-2012, 06:55 PM   #16
LAS97GT's Avatar
What type of shocks/strut will have the power to arrest that spring rate? I ended up going Eibach pro shocks after I found out KYB couldn't handle the rate of the Eibach spring. BTW I have a vert GT. I hate rail road tracks.
---Las97GT
08:04 PM
