front end issues - Mustang Evolution
Old 04-18-2012, 11:07 AM   #1
dmg1092's Avatar
front end issues
Ok I am having a bad popping in my front end its when its under pressure when increasing or decreasing speed and turning into me drive I've just installed new ball joints lower control ARM bushings and sway bar end links and I'm still having popping does anyone have any ideas I'm thinking either struts or motor mounts I'm just lost on this one and don't know where to go next
dmg1092 is offline   Reply With Quote
Old 04-18-2012, 11:16 AM   #2
ColeJohnson's Avatar
Did you fill the ball joints with grease? I forgot to grease mine and had a loud popping noise when I pushed on the fender to compress the suspension and also when I turned hard. Sounds like you have the same issue.
2016 Comp Orange GT (current)
Old 04-18-2012, 01:32 PM   #3
dmg1092's Avatar
Yeah I dis all of that everything is installed properly its the craziest thing when I'm outside the car I can pull and tug and push on different things and the car won't make a sound but the minute I apply brakes or gas its popping again do u know if maybe the k member bolts being loose would cause this problem
Old 04-18-2012, 04:14 PM   #4
Yes.
Old 04-18-2012, 05:16 PM   #5
Dgerow12's Avatar
I'm having the same problem on my sixxer. I just did new shocks and struts all the way around and though Mabye my ball joints were going but I also thought Mabye the bushings or emdlinks of my sway bar... If you find out what it was pm me and lemme kno and I'll do the same
Dgerow12 is offline   Reply With Quote
Old 04-18-2012, 05:25 PM   #6
dmg1092's Avatar
Yeah I got her in the air now trying to figure it out
Old 04-18-2012, 10:59 PM   #7
Disconnect the outter tie rod and turn the front wheels left and right to full articulation to check for the sound. If it still does it then you can rule out most of the steering and look more into the suspension.
Old 04-19-2012, 06:52 AM   #8
jjsg09's Avatar
Could it be the sway bar links?
Old 04-19-2012, 08:31 AM   #9
dmg1092's Avatar
I've already replaced those tho
10:01 PM
