Stripped - Mustang Evolution
Old 04-19-2012, 01:29 AM   #1
Eturner's Avatar
Stripped
Does anyone have or know, of a way to get a stripped out ignition coil bolt out!.. It turns, it just will not come loose!...
Old 04-19-2012, 01:51 AM   #2
It's not me, it's you.
primer2tone's Avatar
Can you get under the head of the bolt, to pry up on it while you turn it?
Old 04-19-2012, 01:55 AM   #3
deadsp0t's Avatar
++^ what he said
That's unimpressive
Old 04-19-2012, 02:17 AM   #4
Eturner's Avatar
No!.. Lol
Old 04-19-2012, 03:03 AM   #5
Eturner's Avatar
Well I can't get between the bolt head and coil!.. But was able to get between the coil and manifold!.. But still didn't seem to do much!..
Old 04-19-2012, 05:09 AM   #6
Are you able to tighten it back down?
If you're not getting anywhere by turning it, you're going to have to grind the head of the bolt off, slide off the coil, then you can get some Vice Grips on the shaft and twist it with some force.
Old 04-19-2012, 05:11 AM   #7
Jlt00bluegt's Avatar
If I remember right the bolt screws into a brass nut molded in the intake. The nut may have worn the plastic out and it's letting the nut spin. You probably don't want to pry it out cause it might brake a chunk out of your intake. I would grind the head of the bolt then JB weld the nut so it don't spin. These bolts don't do a lot so remember they don't have to be that tight. Hope his helps
Jlt00bluegt is offline   Reply With Quote
Old 04-19-2012, 07:19 AM   #8
Eturner's Avatar
Thanks guys!.. Looks like cutting the bolt head off is my only option right now!.. Lol. I need to do something as I've got that coil going out on me!.. Lol
02:05 AM
