what size injectors come in 02 gt - Mustang Evolution
Old 04-20-2012, 10:22 AM   #1
scottiep101's Avatar
will bigger ones do anything to stock engine?
scottiep101 is offline   Reply With Quote
Old 04-20-2012, 11:40 AM   #2
CodyNelson's Avatar
Region: West Virgina
Re: what size injectors come in 02 gt
19 lb and no they wont. No need to upgrade unless you do heads, cams, or FI
Old 04-20-2012, 11:59 AM   #3
6stringz803's Avatar
bigger injectors in a stock engine is gonna make your car waste gas/ foul out spark plugs/ run like shiznit (and not the good kind of shiznit either)
6stringz803 is offline   Reply With Quote
Old 04-20-2012, 12:09 PM   #4
Ok, the smallest they've got at am is 24lb and they say those are good in stock engine. Is this true?
Old 04-20-2012, 01:32 PM   #5
CodyNelson's Avatar
Why would you want to spend money on something that is going to do nothing but waste gas? Plus if you change injectors you have to get your MAF recalibrated. So you do all that work to go right back to stock power? Just doesnt seem smart to me
Old 04-20-2012, 01:37 PM   #6
NeedSomeMods's Avatar
+1 unless you have failing injectors, and/or plan to build more power, there's no reason to swap 'em.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-20-2012, 01:41 PM   #7
I almost positive I've got a bad one. At idle its got a hiccup and when I had it there's a bit of hesitation but if I floor it it goes away. I've changed plugs, suit and fuel filter, had coils checked and it still does it.
Old 04-20-2012, 01:51 PM   #8
Mmustang01's Avatar
It will be worthless if ur thinking on keep ur motor On the 340 hp range
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline   Reply With Quote
Old 04-20-2012, 09:03 PM   #9
I wouldnt unless you have a SCT ECU tuner. the fact is a stock motor isnt designed for them, and even though you might not tear it up immediatly, it could definitly reduce the life of it. If you dont go with the ECU tuner, at least increase the air (turbo/supercharger/Throttle Body), heat up that spark with some msd coil packs. And if you throw the ECU tuner on it after all that, you will have a sick F'ing Stang
P.S.
If you have the tuner, you could do a 93 octane tune and pick up around 30-60 HP depending on your mods. you could adjust shifts in an automatic (if you have one), increase/decrease Compression ratios (for things like N2O, supercharger, etc)
Old 04-20-2012, 10:47 PM   #10
Csnow99gt's Avatar
So would it be best to just replace them with stock injectors from parts store if one is cracked or bad?
Csnow99gt is offline   Reply With Quote
Old 04-23-2012, 10:54 AM   #11
CodyNelson's Avatar
yes
Old 04-23-2012, 12:15 PM   #12
Lorraine's driver
ab_mach1's Avatar
Also, don't waiste your money on any of those super-silly diamond quad split shank whatever spark plugs. Motorcraft!
Instagram: @ab_mach1
Old 04-24-2012, 09:15 AM   #13
robvandam's Avatar
I agree, dont waste your money on crazy spark plugs or fuel injectors. Theres a really good write up on another forum about what the best plugs are for our motors. Also I read somewhere that we actually have 21 or 22 lbs. injectors but ford has it tuned to 19.
Dont hold me to that, I just seem to remember reading it somewhere. Can anyone back me up on that?
robvandam is offline   Reply With Quote
09:37 AM
