is my car faster? - Mustang Evolution
Old 04-20-2012, 10:54 AM   #1
6stringz803's Avatar
is my car faster?
I have a 98 gt 4.6. It had 16" rims with skinny's on the back, I upgraded to 17"s, 245/45/zr17's all four tires. is my car faster now? I know the ride quality is better and it hugs curves better.
6stringz803 is offline   Reply With Quote
Old 04-20-2012, 10:59 AM   #2
Zaks06GT's Avatar
Probably slower. I'm sure the 17's weight more. But not alot to notice, but u should have better traction now
Zaks06GT is offline   Reply With Quote
Old 04-20-2012, 11:01 AM   #3
NeedSomeMods's Avatar
A wider tire will give you more traction, but a larger rim will be heavier. I would say with increased traction you'll be able to launch at a higher rpm without spinning, but unless they're drag radials or a performance tire you won't see huge gains.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 04-20-2012, 11:12 AM   #4
Re: is my car faster?
goodyear Eagle tread wear: 220 Traction: A Temperature: A is on the side of the tires. is this a good brand?
Old 04-20-2012, 12:10 PM   #5
if you take traction out of it its probably slow now since rotational weight is 10x that of dead weight and you made your rims a bit heavier.
Reality, you will have better traction so you will be able to take off harder~ this alone might make the car overall faster.
Old 04-20-2012, 09:37 PM   #6
Csnow99gt's Avatar
I bet the front wheels will come off the ground now! Lol
Csnow99gt is offline   Reply With Quote
07:21 PM
