1/4 times - Mustang Evolution
Old 04-21-2012, 11:08 AM   #1
taylor98gt's Avatar
1/4 times
what will a stock 98 gt 5 speed run?
taylor98gt is offline   Reply With Quote
Old 04-21-2012, 12:26 PM   #2
AgentOrange's Avatar
15's depending on driver.
AgentOrange is offline   Reply With Quote
Old 04-21-2012, 02:12 PM   #3
taylor98gt's Avatar
There was a 97 at the strip lastnight running 13.6s what. Would be the best thing.to do to mine to get the times lower
Old 04-21-2012, 02:24 PM   #4
FORDGT14's Avatar
Re: 1/4 times
Get some gears, a tuner, a CAI, an exhaust, and if you can drive, you should see some better times
I would start with buying the tuner first, yes its expensive, but it allows you to tune every mod you buy for you car and get the full potential out of it. Then get the gears for better acceleration.
FORDGT14 is offline   Reply With Quote
Old 04-21-2012, 02:37 PM   #5
A PI swap, then ^^^
Old 04-21-2012, 03:34 PM   #6
taylor98gt's Avatar
I've been thinking about the pi swap but what all do I need for it?
Old 04-21-2012, 03:54 PM   #7
Not 100% but i'm pretty sure its just heads and intake manifold.
Old 04-21-2012, 04:24 PM   #8
taylor98gt's Avatar
That's what I was thinking it was
---------- Post added at 06:24 PM ---------- Previous post was at 06:24 PM ----------
What gears should I get?
Old 04-21-2012, 10:21 PM   #9
StackeStang's Avatar
Re: 1/4 times
4.10 if its for racing
StackeStang is offline   Reply With Quote
Old 04-21-2012, 11:18 PM   #10
ColeJohnson's Avatar
Re: 1/4 times
Or 4.10 for daily driving.
2016 Comp Orange GT (current)
Old 04-21-2012, 11:36 PM   #11
taylor98gt's Avatar
Re: 1/4 times
so if i get the 4.10s will it be horrible at interstate speed??
Old 04-22-2012, 05:50 AM   #12
No, it will be a little higher RPM but not "horrible". Some of the guys here run 4.10's and can tell you what RPMs they run at interstate speeds.
Old 04-22-2012, 06:36 AM   #13
2002VertGT's Avatar
Look up any post by. Colejohnson and click the link in his sig....
4.10 Gear/RPM thread
Old 04-22-2012, 08:10 AM   #14
2002VertGT's Avatar
Re: 1/4 times
go visit this thread!
4.10 Gear Speed/RPM Video
Old 04-22-2012, 04:25 PM   #15
FLEX4.6's Avatar
I just finished pi swap on my 96 gt 5spd. I ran a 14.6 stock and it has a heck of alot more power now. For the swap, you need H/C/I with, head gaskets, head bolts, intake gaskets etc. then its easy from there. There are write ups all over the net. And I did it by myself.
96 Mustang GT- PI Heads/Cams/Intake, K&N intake, Offroad Catless H with stock mufflers, LuK Pro Gold clutch with built 5 spd t45.
FLEX4.6 is offline   Reply With Quote
Old 04-22-2012, 04:56 PM   #16
Re: 1/4 times
higher RPMs, more gas. smartass
Old 04-22-2012, 05:03 PM   #17
Lorraine's driver
ab_mach1's Avatar
Re: 1/4 times
Did you need to request a new tune for your setup or did they have pre-made setups for you to use?
Instagram: @ab_mach1
Old 04-22-2012, 05:44 PM   #18
FLEX4.6's Avatar
Who?
Old 04-22-2012, 05:47 PM   #19
Lorraine's driver
ab_mach1's Avatar
Originally Posted by FLEX4.6
Who?
I was wondering about after your PI swap.
Old 04-22-2012, 06:18 PM   #20
FLEX4.6's Avatar
No tune yet. Runs perfect with good compression at all cylinders. I am trying to decide if I want Bama Pi tune and do some data logging with them to dial it in, or Jo at trick tuners and do the data logging.
---------- Post added at 07:18 PM ---------- Previous post was at 07:17 PM ----------
They do make a canned pi swap tune from bama, but I doubt it will be enough without sending them some data logs.
Old 04-22-2012, 06:24 PM   #21
BaSohol's Avatar
I get better gas mileage around town with my 410s, if any one is wonder about them or on the fence ask someone that has them, not some who just reads up about stuff and over analyze it
410s are the bees knees
2007 Ford Mustang GT 5spd
Old 04-22-2012, 06:26 PM   #22
Lorraine's driver
ab_mach1's Avatar
Dude who owned my car put 3.73 gears in and had it tuned. I don't know if he went somewhere or did it with a handheld. After tooling through many of the threads on this forum, it seems like I should consider getting a handheld is a must, especially it your going beyond CA kits and cat back. I guess I better save up.
Old 04-22-2012, 06:49 PM   #23
FLEX4.6's Avatar
A handheld is def a good investment and a must have if you plan on doing much with the car.
Old 04-22-2012, 07:03 PM   #24
2002VertGT's Avatar
Wow really??? Is that how that works??? Oh except for when you are city driving and it gets you into the power band faster and you can cruise city streets in 5th gear...and the higher rpms is not that much higher...and neither is the gas consumption...yes it is more but not a lot. He was being serious not a smartass view the thread in my sig.
Old 04-22-2012, 07:11 PM   #25
deadsp0t's Avatar
You already have more power then traction.
Good tires, good clutch, upper and lower control arms and aluminum driveshaft maybe some sub frames if you plan on serious power. HCI etc etc you won't get the most out of any of those power bolt ons with stock suspension parts.
That's unimpressive
Old 04-22-2012, 07:31 PM   #26
taylor98gt's Avatar
Re: 1/4 times
what exactaly is the h/c/i??
Old 04-22-2012, 07:34 PM   #27
2002VertGT's Avatar
I'm gonna go with heads/cam/intake. Although I think the cam might be something else but it's all I can think of with a c right now.
Old 04-22-2012, 07:39 PM   #28
tc x 4's Avatar
I have 4.10s and I don't like them at all. Unless its a strip car, keep ur money its a waste.
Old 04-22-2012, 07:44 PM   #29
I thought about getting some but I love the stock 3.27 on the interstate I can run 90 turning 2,300 rpm
Ryan7racin is offline   Reply With Quote
Old 04-22-2012, 07:51 PM   #30
Lorraine's driver
ab_mach1's Avatar
That's what my '92 GT had. I can tell a big difference in city driving with my Mach w/3.73's. It's more difficult to keep it from being jerky compared to the '92. But, I'm happy with 3.73 and feel like its the perfect compromise.
Old 04-22-2012, 10:20 PM   #31
Mile high JDF's Avatar
Are you asking what it means? 02 GTVert got it right. If you're asking what it's off of then it's off a 99-04 GT
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-23-2012, 02:23 AM   #32
I was not being a smartass. I've been running 4.10s in my '02 GT for over a year and I'd do it again. My city mileage is either un-affected or increased, and HWY mpg has a minimal decrease. Check my signature for a link(WITH VIDEO) of a discussion on the jump from 3.27 to 4.10. There is a lot of discussion about it.
I always say 4.10s are a great choice. And I always will. They are amazing. And if you disagree then back you claims up with something else than just an opinion. You shouldn't try to sway a thread just because you don't approve. And you definitely should not call me anything other than my name. Thanks.
Old 04-23-2012, 04:34 AM   #33
2002VertGT's Avatar
:thumbsup:
Old 04-23-2012, 08:01 AM   #34
Re: 1/4 times
I'm sure multiple people would agree with me. and one sentence is hardly an attempt at swaying a thread. and your previous comment was a bit of a smartass one, i simply pointed it out.
Old 04-23-2012, 08:58 AM   #35
KATO's Avatar
Re: 1/4 times
09:14 PM
