More power - Mustang Evolution
Old 04-23-2012, 05:54 AM   #1
Region: West Virgina
More power
Hi everybody i have a stock 98 mustang gt any suggestion on how to make some quick horse power till I can do some some real work on the motor any help would be great
Mustangnutz is offline   Reply With Quote
Old 04-23-2012, 06:19 AM   #2
taylor98gt's Avatar
Cold air intake, exhaust, gears, tuner, throttle boddy, pi swap for the 96-98gt.
taylor98gt is offline   Reply With Quote
Old 04-23-2012, 09:47 AM   #3
Ok I have flowmaster exhaust on it thanks for the tip will start upgrading on that stuff first what about under drive pulleys are they worth changing to aftermarket or not .
Old 04-23-2012, 10:16 AM   #4
DaBluedude's Avatar
Imo, no. its not worth it.
2003 Mach 1
Old 04-23-2012, 10:23 AM   #5
2002VertGT's Avatar
You will hear soo many different thought on this touchy subject...I have them....I got them for $50 used...if u do go with them go with a SFI certified brand like Steeda...
4.10 Gear/RPM thread
Old 04-23-2012, 10:28 AM   #6
Ok thanks for all the help any other tips you guys can give
Old 04-23-2012, 10:54 AM   #7
StackeStang's Avatar
Re: More power
obviously regular maintenance (oil changes, plugs and such) will not exactly add power, but prevent power loss. adding that with the previously mentioned mods will be beneficial. so far i have a CAI from AM and a SCT SF3 tuner and my car drives better than ever
StackeStang is offline   Reply With Quote
Old 04-23-2012, 11:08 AM   #8
Lorraine's driver
ab_mach1's Avatar
Re: More power
The reason I didn't try'em out was because I have the Mach460 stereo system. I figured w/two amps and everything else, it would be too stressful for the alternator.
Instagram: @ab_mach1
Old 04-23-2012, 11:18 AM   #9
Re: More power
how old is it? you could probably find a more effective one
Old 04-23-2012, 11:39 AM   #10
How old is what my car is a 98
Old 04-23-2012, 11:43 AM   #11
Re: More power
the alternator. you might be able to find one that can handle what you plan to do with it if you're nervous about the one you have now
Old 04-23-2012, 11:49 AM   #12
Lorraine's driver
ab_mach1's Avatar
Was planning on re-visiting when the orig. alternator dies. I was gonna upgrade anyway and it'd be good time. But, we're only talking like 5HP gains, right?
Old 04-23-2012, 11:50 AM   #13
Re: More power
that and if the old alternator can't handle it a new one might prevent problems.
Old 04-23-2012, 12:15 PM   #14
Just had to put a new alternator on it
Old 04-23-2012, 12:17 PM   #15
2002VertGT's Avatar
First off, it only affects power while at idle...secondly it only affects it at idle IF you use the UD alt pulley..if u leave the stock alt pulley on you will be fine
And it frees up hp does not add..
Old 04-23-2012, 12:20 PM   #16
Lorraine's driver
ab_mach1's Avatar
I see. Something to checkout. Have any troubles finding a serp belt that fits right?
Old 04-23-2012, 12:21 PM   #17
2002VertGT's Avatar
Nope
Old 04-23-2012, 03:52 PM   #18
jdavis96gt's Avatar
Re: More power
Don't they use stock belt?
I've heard not to get the piggyback style but have no experience with them, not yet
Old 04-23-2012, 04:21 PM   #19
2002VertGT's Avatar
Originally Posted by jdavis96gt
don't they use stock belt?
DO NOT get the piggy back style!!!
Old 04-23-2012, 04:29 PM   #20
not neccesarily. if you leave the stock alternator pulley on but change the crank pulley the alternator will still spin slower because of the smaller crank pulley. it maynot be affected as much but still will. then this also becomes a hassle because when you change the alt pulley you also need a belt. what i have done before is get a smaller than stock alternator pulley(overdrive). and then use the rest of the ud pulleys. its a hassle so now i just use high amp alternator.
01:42 AM
