Brake light wtf! - Mustang Evolution
Old 04-23-2012, 03:04 PM   #1
Mathew r Wright's Avatar
Brake light wtf!
K guys I guess I got kinda a silly question, but if your third brake light is out (trunk light). Will it automatically make the the taillights not light up when you hit the brakes?
Mathew r Wright is offline   Reply With Quote
Old 04-23-2012, 03:45 PM   #2
Sonicblue11's Avatar
It shouldn't at all, it's hooked up to a different harness
Sonicblue11 is offline   Reply With Quote
Old 04-23-2012, 04:39 PM   #3
Yah that's right at least what I thought. I know I have running lights but the cop told me I don't have brake lights, when I go to brake? I don't know go figure huh...
---------- Post added at 05:39 PM ---------- Previous post was at 05:32 PM ----------
I don't know the whole thing just makes me mad because I keep getting harassed by the police about it...
Old 04-23-2012, 10:55 PM   #4
etc1006's Avatar
Maybe you should check into it, then the fuzz won't hassle you? Just sayin'....
etc1006 is offline   Reply With Quote
Old 04-24-2012, 12:07 AM   #5
Well I fixed the sob once before, but now my taillights won't even light up?
---------- Post added at 01:07 AM ---------- Previous post was at 01:02 AM ----------
And you know I don't really know that much about the whole wiring business? I mean I know it could be a short,bad fuse, or even a brake light switch. But heck I don't even know where to start... It's like one day it all worked, then went the third. And now my taillights don't even light up???
Old 04-24-2012, 12:18 AM   #6
Mile high JDF's Avatar
Look for a fuse, I can't remember where the fuse box is, but that should be the problem.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 04-24-2012, 12:50 AM   #7
Yah the fuse box is in a spot where you have to come in through the passenger side, then turn yourself upside down. Then try to figure out witch fuse it is to test lol... I think it's up under the driver side dash I don't know. I wish I had someone like you to help me out... I really do think it is the brake light switch though...
---------- Post added at 01:50 AM ---------- Previous post was at 01:48 AM ----------
Oh yah " you should check into it" that's what the cop said last night lol... Your not a cop are you!
Old 04-24-2012, 12:58 AM   #8
Ummm should be in the engine bay... if that's the right one. Do you have a Chilton/Haynes manual?
---------- Post added at 06:58 AM ---------- Previous post was at 06:55 AM ----------
U really wish I could remember right now. Once you find the correct fuse box, read the cover and look for one labeled Brake Lights of something similar. Just pull it out and look for broken metal in it.
Old 04-24-2012, 09:21 AM   #9
Yah man I looked and I can't really tell, I mean they all look good to me... I guess I'm gonna stop being lazy and break out the fuse tester...
Old 04-24-2012, 10:27 AM   #10
Just start pulling them out and looking for one thats blown
Old 04-24-2012, 11:22 AM   #11
Yah I'm workin on that now thanks brotha... You know I did just find this 15A that was just taped in there? Wtf? I don't know it seems like everything on this car was just rigged to heck and back! Ahh oh well I'm taking care of it a lil at a time...
Old 04-24-2012, 04:10 PM   #12
Ok so ya can say I told ya so... Because I did end up finding 3 bad fuses, I replaced them, so now everything works now...
Old 04-24-2012, 05:25 PM   #13
Awesome!
Old 08-27-2014, 09:19 PM   #14
Region: Nevada
I have a question just found this site I need some help with my new mustang the break lights work when the lights are on but when I push the breaks they don't get brighter and other then when the lights are on when I press them they still don't work I just put a new break switch in and checked all the fuses and bulbs and everything is fine can some one please help me out it's a 1996 mustang srs thank you
Chase is offline   Reply With Quote
Old 08-27-2014, 09:24 PM   #15
Have you checked to see if you have voltage at the taillight bulbs?
Old 08-28-2014, 12:50 PM   #16
escottcarp's Avatar
Also. If your cruise control doesn't work and the brake lights don't work, check the fuse first. Both circuits are on the same fuse.
Have a big Mustang day!
escottcarp is offline   Reply With Quote
Old 08-28-2014, 02:20 PM   #17
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Also, the switch behind the brake pedal that illuminates your brake lights and deactivates cruise control is something to check. I've heard that one of the wires coming off of it tends to get hot and melts.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-28-2014, 02:50 PM   #18
escottcarp's Avatar
The insulation on that wire can melt and the wire shorts against another metal part, too.
It is difficult to see when it is dark under the dash and you are in a strange position to see under the dash.
I took lots of pics to figure out my problem a few weeks ago.
02:22 AM
