Mark VIII swap? - Mustang Evolution
Old 04-23-2012, 05:44 PM   #1
AgentOrange's Avatar
Mark VIII swap?
Just wondering if anyone on the boards was running a Mark VIII motor? I have heard the swap is relatively simple, but I don't know anyone that has done it. Personally considering this swap and a Vortech when the time comes to make mine morr of a "go" car.
AgentOrange is offline   Reply With Quote
Old 04-23-2012, 06:06 PM   #2
DaBluedude's Avatar
Its basically the same as a cobra swap. make sure you get the computer. i love a vortech blower.
2003 Mach 1
Old 04-23-2012, 06:08 PM   #3
32vNomad's Avatar
Well if you want to build a motor from the bottom up that will give you a better platform to buid hp then go with the 4v. Now if you get a Mark motor try for a 97-98 as they have upgraded behive springs. But the bottom end is going to have to be fortified anyways. I myself went with a mark 4v. Now I forged the bottom end and ported the B series heads. Worked the intake and made IMRC deletes. I've done the work my self with the exception of the machine work. Now I went with the 4v for future endevors. The block alone is worth it to me. Now I won't lie it is expensive but there a lot of parts that can be found here. If you decide to look into the 4v look my club up on facebook. We have a guy that did a v6 to 4v swap, also there are many photos of my build. Facebook.com and search for War Horse Mustang Club. Everyone is welcome!!
32vNomad is offline   Reply With Quote
Old 04-23-2012, 06:12 PM   #4
32vNomad's Avatar
You don't need the computer. For the swap. It will need to be dyno tuned but will run on the 99-04 ecm. Things I'm not using... EGR valve and sensors, and Knock sensors (GT's don't have those).
Old 04-23-2012, 06:24 PM   #5
Right. I heard all you really need to change are heater hoses and remove egr equipment, and of course knock sensors.. I plan to source a 97+ motor mostly for the factory coil-on-plug, but knowing it has other benefits only sweetens the pot. I'll be honest.. I was going to run 8psi on a stock rotating assembly.
Side question. My mustang misfires at random. Without knock sensors, how does it detect the misfire? Crank sensor?
Old 04-24-2012, 01:00 AM   #6
32vNomad's Avatar
8 psi would be fine on the Mark motor. If you find some 99-01 cobra cams they work well with boost. 96-98 cams are the most aggressive NA cams. Plus the block alone is worth the cash. Its an aluminum block that is on top for handling big hp.
---------- Post added at 01:00 AM ---------- Previous post was at 12:56 AM ----------
That and cam sensor. But if your motor is randomly misfiring check coils . Is it underload are at idle?
Old 04-24-2012, 08:45 AM   #7
Idle. Does it intermittently. I suspect the coil. Only on #5. I'm looking into it tomorrow
Old 04-24-2012, 12:31 PM   #8
32vNomad's Avatar
Swap the coil with a known good hole and see if the problem migrates to the new hole.
Old 04-24-2012, 10:45 PM   #9
6stringz803's Avatar
Re: Mark VIII swap?
would this motor work on a 98 gt without doing an ecu swap? private message as the next time i get on (tomorrow after work) this post will probably be pushed back and i would forget to look.
6stringz803 is offline   Reply With Quote
Old 06-17-2012, 12:38 PM   #10
32vNomad's Avatar
Re: Mark VIII swap?
Step by Step guide to installing a Mark VIII motor in a 96+ GT. - MustangForums.com
"Installing the motor extremely tough to do with the K member and/or the transmission still in the car. It is IMPOSSIBLE to install this motor with the K member bolted in and the transmission still in the car. I had to unbolt the transmission and lower/slide it out of the way, then mount the engine on the K member. Then I had to set the car on the ramps, unbolt the K member and lift the body up enough to bolt the transmission to the engine. *I also believe that it will be near impossible to install the engine with the transmission bolted to it due to clearance issues, but I can not confirm this*" I do not agree with this section since it is actually how I did it. But the right up seems sound. I will be doing one myself that has more in depth explanations and photos. For a 99-04 New Edge.
09:24 PM
