My tires in the front - Mustang Evolution
Old 04-23-2012, 10:03 PM   #1
02stangswagg's Avatar
Y tires tread is getting wasted from only the inside of the tire can it be that the springs are cut someone help
02stangswagg is offline   Reply With Quote
Old 04-23-2012, 10:05 PM   #2
02gtsilver's Avatar
Your front end might need to be alligned or you need to get your tires balanced. Either of those can make your tires wear funny
02gtsilver is offline   Reply With Quote
Old 04-23-2012, 10:48 PM   #3
Venomouz831's Avatar
I think you're most likely cambering.. Mayb need CC plates
)02 Gt, Founder of WE2G
Old 04-24-2012, 01:23 AM   #4
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
You have excessive negative camber and or toe. Camber/caster plates or camber bolts and an alignment will clear it up.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 04-24-2012, 04:02 AM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
Cut springs sound like the culprit to me. C/c plates are probably the answer
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-24-2012, 08:20 AM   #6
So I basically need new springs and cc plates with an alignment of everything
Old 04-24-2012, 08:32 AM   #7
jjsg09's Avatar
Anytime the front suspension is messed with it should need an alignment
Old 04-24-2012, 08:49 AM   #8
True so I will need new springs a cc plates
Old 04-24-2012, 10:59 AM   #9
kelidd's Avatar
I would definitely get new springs,cc plates and then get tires and alignment at the same time
kelidd is offline   Reply With Quote
Old 04-24-2012, 11:01 AM   #10
How is your ride? If you're happy with how it handles bumps and imperfections in the road then you just need to correct your front end alignment. Otherwise you may want new springs. Both toe and camber can affect tire wear greatly. With that said, you can save your self some cash and get some camber bolts for around $25 (american muscle has them) and an alignment should be from $60-$80. This will correct your tire wear problem.
Old 04-24-2012, 11:09 AM   #11
I like it so just get the bolts and align it
Old 04-24-2012, 11:23 AM   #12
robvandam's Avatar
Re: My tires in the front
Is your car lowered? If so and its lowered by cutting the springs then yes, definitely without a doubt replace your springs. If you want to lower the car do it right.
If its not lowered CC plates prob will not do anything for you. Have you hit/ ran over anything lately? Curbs, potholes, etc.?
Could be something simple like a tie rod end... Either way figure out the issue, then buy new tires and align the front end.
"They that can give up essential liberty to obtain a
little temporary safety deserve neither liberty nor safety." -Ben Franklin
The democracy will cease to exist when you take away from those who are willing to work and give to those who are not. - Thomas Jefferson
robvandam is offline   Reply With Quote
Old 04-24-2012, 11:45 AM   #13
The Blue Dragon
Agreed, bad alignment eats up tires and get the right springs, don't be cheap and cut them. If you lower, I recommend c/c plates as well because it will throw off camber and still eat tires
Old 04-24-2012, 12:47 PM   #14
Yes. I know of a lot of people who have cut springs and are happy with the ride. In every day driving they should be fine. A proper set of springs like H&R would be preferable, especially if you drive aggressively or do any type of track days or auto x's. But as long as you're happy with the ride, all you need are camber bolts or plates and an alignment. Any shop should know what to do, but this is a good street alignment set up:
1degree of negative camber
caster: 4-5 degrees
and toe 0 degrees.
Old 04-24-2012, 01:31 PM   #15
Thanks
Old 04-24-2012, 02:32 PM   #16
My pleasure. I have the Eibach camber bolts from American Muscle and they gave me plenty of adjustment for the set up I wanted. I'm running 1.5 degrees of negative camber and the car turns in so much better than stock spec camber which is around .5 degrees.
Old 04-24-2012, 02:55 PM   #17
wheelman's Avatar
Just the info Ive been looking for; thanks.
wheelman is offline   Reply With Quote
Old 04-24-2012, 04:29 PM   #18
Your welcome
» Members Mustangs
Millie
1ijack
Shadow
FLGator
Add your Mustang
03:07 AM
