fan relay horsepower gains on a 98 gt - Mustang Evolution
Old 04-25-2012, 07:32 PM   #1
6stringz803's Avatar
If i ran my fan to a toggleswitch, how many horses would i pick up from cutting out some of the parasidic drain?
6stringz803 is offline   Reply With Quote
Old 04-25-2012, 10:59 PM   #2
kelidd's Avatar
Very little to none plus you run the chance of overheating you engine
kelidd is offline   Reply With Quote
Old 04-26-2012, 12:30 AM   #3
You won't get any gain at all...all it does is mess your car up and will probably cause over heating....plus it's an electric fan...you don't have any loss of power because of it
96gt014.6 is offline   Reply With Quote
Old 04-26-2012, 12:49 AM   #4
deadsp0t's Avatar
This
That's unimpressive
Old 04-26-2012, 07:19 AM   #5
Lorraine's driver
ab_mach1's Avatar
+1
Only benefit I could see by this is when you are in line at the drag strip.
Alternative would be to unplug your A/C compressor. Then you'd just turn on the A/C in your car. This automatically turns on the electric fan.
Instagram: @ab_mach1
Old 04-26-2012, 10:44 AM   #6
Originally Posted by Azure
+1
I wouldn't want to run my car down a drag strip without having my fan working that's for sure
---------- Post added at 10:44 AM ---------- Previous post was at 10:42 AM ----------
Also to add on to this, just turn your a/c off and don't run it when you are going down the drag strip. The a/c motor running will rob you off about 3 horses
Old 04-26-2012, 10:46 AM   #7
Lorraine's driver
ab_mach1's Avatar
Re: fan relay horsepower gains on a 98 gt
Should be ok if you disconnect the A/C compressor under the hood. Unless there is something else running inside (other than the blower).
...Might be able to remove a fuse to get the job done. You'd want to check to see if there is anything else you need that shares that fused circuit.
Old 04-26-2012, 10:48 AM   #8
Hell if he wants to not run his fan just unplug the fan.
Old 04-26-2012, 10:50 AM   #9
Lorraine's driver
ab_mach1's Avatar
Just saying there's a way to force the fan on w/o modifying the circuit, like adding a toggle switch
Old 04-26-2012, 11:06 AM   #10
Yeah, thats true, i just recently got done fixing my car because of that. Had to buy a whole new fan assembly because the owner before me messed it all up, thinking it would help with well horsepower. I can tell you I didn't notice a difference at all from when it was like that and when it's how it is suppose
To be
Old 04-26-2012, 05:14 PM   #11
kelidd's Avatar
Electric fans really do not cause parasitic drains on the engine if it was a clutch fan mounted to the engine it would be a different story
Old 04-26-2012, 06:04 PM   #12
BaSohol's Avatar
On my old car I hooked up my fans to a toggle they still came on automatically but I could turn them on in the staging lanes at the drag strip
2007 Ford Mustang GT 5spd
06:12 PM
