99-04 Gt Fuel Pump - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 04-27-2012, 08:12 PM   #1
FORDGT14's Avatar
FORDGT14 is unknown around these parts
Exclamation 99-04 Gt Fuel Pump
Ok first off, My car was sputtering really bad, I figured the fuel filter might be clogged so I bought a new one and put it in. Well now it's still sputtering, and getting worse. Im guessing it might be the pump, I found a pump on ebay and I'm not too sure about it.
Here's a link, let me know what you guys think.
255LPH HIGH PRESSURE FUEL PUMP+1-140 PSI ADJUSTABLE BLUE REGULATOR+GAUGE/GAUGES | eBay
The pump's at Autozone are around $120, and only about $40 for just the pump on ebay. So obviously I'll be buying from ebay.
But if anyone else has any bright ideas as to what the problem could be if not the pump. I'm all ears.
Thanks guys.
FORDGT14 is offline
Old 04-27-2012, 11:24 PM   #2
kelidd's Avatar
kelidd is unknown around these parts
Have you checked your spark plugs?
kelidd is offline
Old 04-28-2012, 12:23 AM   #3
FORDGT14's Avatar
Re: 99-04 Gt Fuel Pump
The plugs are brand new, they have maybe $5k miles on them since the engine was rebuilt. I'll check them tomorrow though, I didn't think about that lol
Do you think they would already be bad with so little miles on them?
FORDGT14 is offline
Old 04-28-2012, 03:37 AM   #4
t0t4lbl4ck0ut's Avatar
t0t4lbl4ck0ut is unknown around these parts
Could have a bad plug, could be a bad coil, pump, fuel lines could be clogged, injectors, o2 sensors. I think you get the point. It can be really anything on the car.
t0t4lbl4ck0ut is offline
Old 04-28-2012, 09:21 AM   #5
kelidd's Avatar
I agree needto check stuff one thing at a time to rule it out before I would condemn the fuel pump I would check you fuel pressure first
kelidd is offline
Old 04-28-2012, 10:43 AM   #6
Mzilla's Avatar
Mzilla is unknown around these parts
Most likely a coil pack
Mzilla is offline
Old 04-30-2012, 09:09 PM   #7
FORDGT14's Avatar
Ok, so this is what I have done so far. I bought and installed a new fuel filter, removed all plugs and gaped them all again to 54. I tried unplugging the coil packs while to the car idled to see which one would make it bogg down the most and they all sounded the same when I individually unplugged them. How else can I check coil packs? And what else can I check? I'm debating on just taking it to Meinekee because they offer a free diagnosis.
What do you guys think?
FORDGT14 is offline
Old 04-30-2012, 09:27 PM   #8
That might be what I'd do at that point lol
---------- Post added at 03:27 AM ---------- Previous post was at 03:26 AM ----------
You can take the coils and test the ohm resistance
Old 04-30-2012, 09:37 PM   #9
FORDGT14's Avatar
How do I do that?
FORDGT14 is offline
Old 04-30-2012, 09:39 PM   #10
With a multimeter or ohm meter. If you take them to auto zone or most auto parts stores they should be able to help you
Old 04-30-2012, 10:46 PM   #11
Codysmustang's Avatar
Codysmustang is unknown around these parts
idk if this will help you or not but it was an issue that i had for a while.. when take the pump out u might want to check the inside of your tank.. mine got water in it and rested the inside of my tank so i had to replace it. might be worth looking into at least.
Codysmustang is offline
Old 05-01-2012, 07:44 AM   #12
Robbie94gt is unknown around these parts
This is just a idea but if your check engine light ain't on then your coils and all that should be good. But I believe if it's a fuel problem then your check engine light won't come on but I'm not 100% sure tho
Robbie94gt is offline
Old 05-01-2012, 09:27 AM   #13
02PONY's Avatar
02PONY is unknown around these parts
That's false I've had 5 coils go bad only 1 threw a code
---------- Post added at 09:27 AM ---------- Previous post was at 09:25 AM ----------
Just buy one coil install it on the first cyl drive it for 5-10 mins see if it makes a difference if not start working your way around each cyl to u find your problem
02PONY is offline
Old 05-01-2012, 09:46 AM   #14
Thsts y I said I'm not 100% sure. But that's how the 86-95 mustangs r. My bad
Closed Thread
10:00 AM
