31 spline rearend on 2003 mustang gt. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 04-29-2012, 01:32 PM   #1
Speed_Mister's Avatar
Speed_Mister is unknown around these parts
Im putting on 31 spline axle and a posi differential with 4.10 gears. Am i safe to use slicks/Drag radials? like i wont break my axle will I with sticky tires? and what should i launch at with slicks or radials? my mods are BBK cold air intake, throttle body spacer, steeda underdrive pullies, with Flowmasters. with 8.8 inch. 31 spline rearend with 4.10's.
2003 Mustang GT 5 speed Manual: BBK Cold Air Intake, Trick Flow 75mm tb/p, Steeda Under Drive Pulley's, SCT Bama 93 Race tune, BBK O/R X-Pipe, Flow Masters Mufflers, King Cobra Clutch, 31 Spline Differential, 31 Spline Moser Axles, 28X10.5-11.5 Hoosiers Quick Time Pro Drag Slicks, 60ft 1.75, 330ft 5.28, 1/8 8.25 @ 83, 1000ft 10.65 @ 94.
Speed_Mister is offline
Old 04-29-2012, 01:56 PM   #2
t0t4lbl4ck0ut's Avatar
t0t4lbl4ck0ut is unknown around these parts
I'd hope your rear end wouldn't break with that kind of power lol I've read that with the 31 spline it's the diff that usually goes before anything else. What kind did you get.
t0t4lbl4ck0ut is offline
Old 04-29-2012, 02:00 PM   #3
it came out of a explorer. i heard ford explorers diff. can handle lots of power.
---------- Post added at 02:00 PM ---------- Previous post was at 01:57 PM ----------
oh my cars tuned too. if that makes a difference.
Old 04-29-2012, 02:19 PM   #4
Idk about a explorer rear end. I know if you bought moser axels and a aftermarket diff you'd have a very very strong rear end.
Old 04-29-2012, 02:20 PM   #5
they are moser 31 spline axles.
Old 04-29-2012, 02:22 PM   #6
Ah. Well with it being a 31 spline I'd figure it's gonna last longer then a stock 28 spline
Old 04-29-2012, 04:07 PM   #7
Rm360's Avatar
Rm360 is unknown around these parts
I had to ford explorers and both ended with the same problem , leaky axel seals , caused from the drag from towing. The force put on the axels and bearings and seals wears out the housing causing the leaks once they start to leak its almost impossible to get them to stop because the housing becomes ovaled out. IMO I would consider getting a rear out of a mustang
Rm360 is offline
Old 04-30-2012, 01:06 PM   #8
arent they stronger than the mustang differential im wanting to be able to launch my car at higher rpms with sticky tires for drag racing.
Old 04-30-2012, 06:47 PM   #9
aegischief's Avatar
aegischief is unknown around these parts
Not sure if the explorer and F150 differentials are made differently or not, but I had a F150 unit with 2 extra clutches in my cobra and it never gave me any trouble. I actually broke 2 eaton differentials before switching to the f150 unit.
I was using moser 31 spline axles with Nitto DRs. Drove it like I stole it when I was at the track.
aegischief is offline
Old 04-30-2012, 07:42 PM   #10
tc x 4's Avatar
tc x 4 is unknown around these parts
My f150 has 330,000 mi never a prob with rear end or seals.
tc x 4 is offline
Old 05-01-2012, 04:05 AM   #11
Rm360's Avatar
The explorer came with 2 different tow packages, standard package was stock suspension , 4x4, trans cooler, etc. and 3.55 gears. The upgrade was the heavy duty package with upgrades to all the above plus 3.73 gears. I should of stated mine were both standard and IMO suspension and such was the cause for failure . If the rear came out of a explorer with the heavy duty package I have no doubt you'll be fine. The f150 rear is a proven winner.
Rm360 is offline
Old 06-08-2012, 04:25 PM   #12
Well I had my 31 spline axles, 4.10 gears, and f-150 differential installed. Took it too the track with slicks launched at 5500 rpm didn't break anything ran a 1.7 60 foot.
Old 06-08-2012, 05:41 PM   #13
Mmustang01's Avatar
Mmustang01 is unknown around these parts
+1
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline
Closed Thread
2003 mustang
06:59 AM
