clutch problems - Mustang Evolution
Old 04-29-2012, 02:22 PM   #1
2000steeda029's Avatar
Region: West Virgina
clutch problems
I was pressing my clutch pedal to the ground when I heard a loud bang, now I have no pedal it sinks to the ground and I have to lift it with my foot. Any suggestions would be nice.
2000steeda029 is offline   Reply With Quote
Old 04-29-2012, 02:28 PM   #2
t0t4lbl4ck0ut's Avatar
Cable could have snapped. Lift the car and on the tranny youll see a rectangle box thing held on by 1 screw. Take that off and you'll see the clutch fork and should see the cable. If the cable is there press on the fork and if you can push it forwards without much effort then there's something else wrong. I'd look to see if the fork itself broke at that point.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 04-29-2012, 02:31 PM   #3
OK will do I have a new cable quadrant and adjuster but wanted to figure out if was the clutch or not... this is my first mustang had a couple dsms and the wife had a 350z
Old 04-29-2012, 02:34 PM   #4
That's what my thought is. Idk where to send ya looking if that's not it.
Old 04-29-2012, 03:48 PM   #5
mcvicar04's Avatar
Yeah. Check the cable it could have stretched out or the end point could have broke. Also when you take the dust shield off you can see the clutch and fork use a flash light and look in you'll find your problem in there more than Likely
mcvicar04 is offline   Reply With Quote
Old 04-29-2012, 06:38 PM   #6
Well new cable quadrant and firewall adjuster in problem solved runs great thanks for everyones input... found out dust shield is missing need to find one and the screw for it
Old 04-29-2012, 07:14 PM   #7
mcvicar04's Avatar
Yea my friend was missing also check you local junk yard for one I think they're pretty pricey online
Old 04-29-2012, 08:30 PM   #8
There is enough mustang guys around here to find one... and a couple junk yards
01:05 AM
