Question lowering your car - Mustang Evolution
Old 04-30-2012, 08:42 AM   #1
RUNNWLD's Avatar
Region: Utah
If my car is all stock with suspension and I want the stance of the h&r springs what all do I need to get to lower it?
RUNNWLD is offline   Reply With Quote
Old 04-30-2012, 08:46 AM   #2
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Question lowering your car
well the best way to do is to buy the H&R lowering springs and pair camber caster plates. you may want think about replacing the shocks and struts as well. other then that you'll be fine.
SaturnMan8227 is offline   Reply With Quote
Old 04-30-2012, 08:51 AM   #3
RUNNWLD's Avatar
Region: Utah
So just the camber plates springs and shocks and struts an ill be good no problems then when I get some more money I'll get some other suspension?
Old 04-30-2012, 08:52 AM   #4
mainly springs and caster/camber plates (maximum motorsports would be the brand I woudl go with for those)
you can reuse your stock isolators or replace with OEM if they are damaged (they are probably ok).
other than that if you want shocks/struts or the car has high miles they may be in need of replacing~
Old 04-30-2012, 09:05 AM   #5
RUNNWLD's Avatar
Region: Utah
Okay thank you guys I appreciate it!!
08:25 PM
