Car not starting?!! - Mustang Evolution
Old 04-30-2012, 09:32 AM   #1
Csnow99gt's Avatar
Car not starting?!!
So my car doesn't seem to be getting power to starter, what could this be, what is the switch that allows the car to start when you push in clutch? Do they go bad?
Csnow99gt is offline   Reply With Quote
Old 04-30-2012, 05:10 PM   #2
jjsg09's Avatar
Are you sure the starter isnt bad?
Old 04-30-2012, 06:16 PM   #3
Csnow99gt's Avatar
Not sure but it doesn't sound like the stater is getting any power
---------- Post added at 07:16 PM ---------- Previous post was at 06:48 PM ----------
If it were my starter wouldn't I here something at the starter, it's like turning the key without pushing in the clutch expect I am pushing in clutch, could this be the ignition switch, clutch pedal Ignition lock switch, or is it my starter
Old 04-30-2012, 06:57 PM   #4
jjsg09's Avatar
Best way to check if a starter is bad is turn on your headlights and when you try to start it the headlights will dim when the starter draws power. If it doesnt dim when you start it more than likely the starter is bad or you have a bad cable going to the starter. You may need someone else to watch the headlights while you try starting the car.
Old 04-30-2012, 07:05 PM   #5
Csnow99gt's Avatar
The car will not even get power to the starter it does not turn over at all
Old 04-30-2012, 07:21 PM   #6
tc x 4's Avatar
Check ur ground . Then see if clutch switch is getting power, nex see if clutch switch has power leaven. Not shur if its an open or closed circut
01:29 PM
