Metallic noise - Mustang Evolution
Old 04-30-2012, 09:41 AM   #1
Lorraine's driver
ab_mach1's Avatar
Metallic noise
Have this metallic noise that is only around the 2000RPM range. This only happens while driving in any fear around said RPM. This noise pretty much goes away or is greatly reduced after driving a few minutes. Its not really a whine, it's metallic, like metal in metal. Is that the clutch? Thanks
Instagram: @ab_mach1
Old 04-30-2012, 12:22 PM   #2
CodyNelson's Avatar
Region: West Virgina
Re: Metallic noise
I had the same thing and it ended up being some bolts that had come loose on my exhaust. Check all bolts and make sure they are good and tight. Id bet that is the culprit. Also, if you have cats the heatshields on them are prone to coming loose and making a very similar noise so I would check there as well
Old 04-30-2012, 12:36 PM   #3
Lorraine's driver
ab_mach1's Avatar
Thanks, I'll check that out tonight. Did your pretty much go away as the car got warmer too?
Old 04-30-2012, 01:04 PM   #4
mcvicar04's Avatar
Mine does that and I have a cracked bell housing
mcvicar04 is offline   Reply With Quote
Old 04-30-2012, 01:05 PM   #5
Arron's racecar's Avatar
Region: Nevada
It could have been that just by the simple fact that metal expands when it heats up.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 04-30-2012, 01:14 PM   #6
Lorraine's driver
ab_mach1's Avatar
So the shields could be resonating with the motor or motor/drivetrain in motion. The part expands and changes the resonance. K, will check all this out. Thanks to you both
Old 04-30-2012, 01:16 PM   #7
Region: Nevada
Good luck!
Old 04-30-2012, 02:14 PM   #8
CodyNelson's Avatar
Re: Metallic noise
mine never went away untill i tightened everything back up. If it is the heat shields you can just rip them off there
Old 04-30-2012, 09:51 PM   #9
BigB227's Avatar
Yeah I got a loose bolt where the headers bolt to the H pipe and it makes that noise as well at around 2000ish RPMs
BigB227 is offline   Reply With Quote
Old 04-30-2012, 10:16 PM   #10
Lorraine's driver
ab_mach1's Avatar
Gonna check mine out Tuesday cause we had some serious rain today (daily driver). I'm hoping it's something like this.
Old 05-02-2012, 02:16 PM   #11
Lorraine's driver
ab_mach1's Avatar
I checked things underneath while changing oil last night. Everything seems good. Were the heat shields you mentioned the ones on the cats? If so, they seemed tight. Exhaust was good to. Is there anything engine related I could check? Transmission related? Thanks!
Old 05-02-2012, 07:37 PM   #12
kelidd's Avatar
Does the noise go away when you press in the clutch? Or can you reproduce it when you rev the engine to 2k with it in neutral while stopped?
kelidd is offline   Reply With Quote
Old 05-02-2012, 08:13 PM   #13
Lorraine's driver
ab_mach1's Avatar
I'll try 2k unloaded tomorrow morning. It will stop when you put the clutch really cause the RPM gets out of that ~2000 range. The sound is only when it's cold. It goes away after maybe 5min of driving. Unless I hear it tomorrow morning unloaded at 2k, it has only been when you are in gear and driving with the engine in that RPM range. It's definitely a bother. Doesn't seem likes it's gotten any worse, but it's loud enough I think people notice it out of the car.
Old 05-03-2012, 08:12 AM   #14
Lorraine's driver
ab_mach1's Avatar
Checked it out this morning when it was cold. Now noise/metallic sound is present when increasing RPM from idle out of gear. Driving, it doesn't matter what gear, it's always right around 2000RPM range in any gear.
Old 05-03-2012, 12:23 PM   #15
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
Re: Metallic noise
Its the throwout bearing. sounds like what happened to my V6
SaturnMan8227 is offline   Reply With Quote
Old 05-03-2012, 12:36 PM   #16
Lorraine's driver
ab_mach1's Avatar
Did your noise go away once it was warm (3 to 5 minutes? Noisy at certain RPM? Just curious. You'd think the TOB noise would not go away when it warms up.
Old 05-03-2012, 12:49 PM   #17
Re: Metallic noise
I heard it through the entire RPM band. And it got really loud when i stepped on the clutch. Take your car in and have it inspected. hearing any metal on metal noise is not good.
Old 05-03-2012, 01:17 PM   #18
wheelman's Avatar
Turn down the Metallica
wheelman is offline   Reply With Quote
Old 05-03-2012, 02:45 PM   #19
Lorraine's driver
ab_mach1's Avatar
Old 05-03-2012, 08:29 PM   #20
Re: Metallic noise
lol
« Coil ohm? | problem »
12:40 PM
