Exhaust leak... Loss of power and MPG? - Mustang Evolution
Old 01-12-2008, 07:15 AM   #1
I have an exhaust leak in on the right side at the h-pipe/collector. Is it just in my head or is my car running like poop with the leak? Also Could this affect MPG?
Mike
Sxynerd is offline   Reply With Quote
Old 01-12-2008, 10:58 AM   #2
Re: Exhaust leak... Loss of power and MPG?
Too complicated a question for ME members?
Old 01-12-2008, 11:58 AM   #3
Too early in the morning on a saturday lol.
Depending on the size of the leak it could lead to problems. If you know where it is why not fix it? May be as simple as tightening down the collecter/midpipe bolts.
Old 01-12-2008, 04:28 PM   #4
Thomas91169's Avatar
my sentiments exactly.
exhaust leaks (especially pre-cats) can cause lots of issues. if the exhaust is leaking before the front o2 sensors they are getting strange readings than they should be, and thusly could be fooling your ecu into running very rich or little timing or whatnot.
simple solution = fix the leak.
-Thomas-
Old 01-12-2008, 05:27 PM   #5
wiarumas's Avatar
id assume it wouldnt pass inspection either. depending on the leak's location, size, etc it could be very simple and/or cheap. the loss of MPG might be directly related to the leak or the leak might just have decreased performance which causes you to drive harder? i dunno im not that knowledgable on that subject matter.
Old 01-12-2008, 06:57 PM   #6
I'll get around to it in a few days; I was just wondering any side effects because of it. I don't drive my car "very often" now that it's winter but I did take a trip down to KY this week and was wondering if it could have anything to do with my "feeling" of lack of power. It's like I'm driving with the A/C on.
No inspections in the horrible state of Michigan. It's the states only redeeming quality. I have noticed a slight decrease of MPG in the city but the freeway with my tune I still manage to get 28.6 MPG at 65-70mph.
Thanks for the input guys.... Also, I just assumed, since I was up, everyone was up!
Old 01-16-2008, 09:10 PM   #7
with the engine running go to the passenger side on the engine and accelarate the car and and let it go quick if you see smoke coming from the back of the engine bay you will need to replace the gasket that goes in between the header and the exhaust pipe.
gerardo is offline   Reply With Quote
Old 03-01-2008, 07:08 AM   #8
yes car will run like poop with a leak that used to happen on my 92 gt with bbks shortys the bolts would come loose on headers and blow gasket happend twice till i bought locking bolts pain in the *** and drove me nuts always lossd hp with the small lak u prop blew the gaskey if bolts are loose by the collecter
ros04gt is offline   Reply With Quote
exhaust
MPG and some power raydavis Pre-2005 V6 Mustang 2 04-09-2010 10:05 AM
V6 Loss of horse power wyatt-00' Pre-2005 V6 Mustang 19 01-27-2010 08:29 AM
Loss power and overheat, jerking, please help!!! kevpar07 Pre-2005 V6 Mustang 4 09-08-2007 10:25 PM
93 POWER LOSS jcori3 1979-1995 Mustang GT 17 09-19-2006 06:41 AM
power loss? 6erstang Pre-2005 V6 Mustang 7 09-03-2003 09:39 AM
07:07 AM
