New intake manifold installed , little bit of a bog when i step on the gas. - Mustang Evolution
Old 05-01-2012, 08:39 PM   #1
So I just installed my new intake manifold. Everything looks like its right, no leaking everything looks fine. BUT, when i step on the gas it starts bogging or studdering. Do not know what it is, and cant figure it out. Ideas?
Jdunx98GT is offline   Reply With Quote
Old 05-01-2012, 09:18 PM   #2
Stevo1168's Avatar
Recheck your plug wires. My intake is cracked so that will be my next project as well. Hope it all works out.
Stevo1168 is offline   Reply With Quote
Old 05-01-2012, 09:21 PM   #3
Re: New intake manifold installed , little bit of a bog when i step on the gas.
Did that, might need to triple check. But its not mis-firing or anything like that. Enjoy your installation.
Old 05-01-2012, 09:23 PM   #4
813floridaracin's Avatar
Did you by chance damage the intake sensor?
813floridaracin is offline   Reply With Quote
Old 05-01-2012, 09:30 PM   #5
no codes have popped up. ive only driven it a mile so far, but had it running for longer.
Old 05-01-2012, 09:45 PM   #6
02PONY's Avatar
Double check all your bolts for plenum air intake also make sure all your injectors are completely connected
02PONY is offline   Reply With Quote
Old 05-03-2012, 12:15 AM   #7
Vegas97gt's Avatar
Region: Nevada
Normally bogging is getting too much air right? Is it an aftermarket for more or better air flow or a stock replacement?
Vegas97gt is offline   Reply With Quote
Old 05-03-2012, 01:54 PM   #8
for my 98 they made the intake manifolds with plastic (where it cracked) now they have made it with metal because people were having a lot of problems. Its nothing special, bought it off ebay for 170. Metal plated now.
Old 05-03-2012, 03:26 PM   #9
kelidd's Avatar
Check you connections if ask of that checks out I would check for vacuum leaks around the manifold and throttle body take some carb cleaner a and spray around and see If the engineepms change if it does there's your leak
kelidd is offline   Reply With Quote
Old 05-03-2012, 03:41 PM   #10
Randl114's Avatar
I had the same problem when I did my intake. Turns out I had just routed the wires wrongly. Make sure your mass air flow is plugged in. Good luck.
Your enemy is doing what you can not. When you meet he WILL defeat you.
Randl114 is offline   Reply With Quote
04:47 PM
