new tuner isues - Mustang Evolution
Old 05-03-2012, 08:08 PM   #1
Randl114's Avatar
new tuner isues
I just installed my new sct tuner chip. Now the car won't start. Anybody have this happen to them. I sprayed with starting fluid and it runs. I am no longer getting fuel, what is going on.
Your enemy is doing what you can not. When you meet he WILL defeat you.
Randl114 is offline   Reply With Quote
Old 05-03-2012, 08:13 PM   #2
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
It might help to reflash back to stock to see if it's the tune. It could be your fuel pump.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 05-03-2012, 08:23 PM   #3
Randl114's Avatar
That would be awfully coincidental. I drove it into the garage.
Old 05-03-2012, 08:29 PM   #4
xhgwx's Avatar
I had the same problem with mine, I reinstalled in 4 times and cleaned it very well.
Eventually just took it out
Was a POS for me
xhgwx is offline   Reply With Quote
Old 05-03-2012, 08:31 PM   #5
I had this problem when my programmer locked up I returned it back to stock and it cranked right up.
I have heard that the chips have this problem often.
Ryan7racin is offline   Reply With Quote
Old 05-03-2012, 10:17 PM   #6
StackeStang's Avatar
Re: new tuner isues
if its the chip that goes into the computer then yeah. My car would randomly shut off while i was driving. needless to say i sent that POS back and now have the SCT SF3 tuner than just plugs into the car under the steering wheel
StackeStang is offline   Reply With Quote
Old 05-04-2012, 08:22 AM   #7
xhgwx's Avatar
Mine also randomly shut off in the middle of driving!
Extremely dangerous,
I just pulled mine out, A.M states no returns on tuners or chips, so I just kept it.
I'm getting a tuner soon.
Old 05-04-2012, 08:32 AM   #8
Randl114's Avatar
Re: new tuner isues
I gave up on it last night as it was getting late. Before I put the chip in, when I would turn the key to on, I could always hear the fuel pump. With the chip in I can't hear it. I don't know if it is the chip or if I coincidently need a pump now. Hopefully it is just the pump relay.
Old 05-04-2012, 08:50 AM   #9
02PONY's Avatar
Is it new or did u buy it from someone
02PONY is offline   Reply With Quote
Old 05-04-2012, 09:34 AM   #10
Randl114's Avatar
Re: new tuner isues
It is new. Recieved it yesterday from American Muscle.
Old 05-04-2012, 10:23 AM   #11
I've had my SCT chip in my Termi for a month now and zero problems. I'm actually quite satisfied with its performance ... The race tune is incredible !!!
I took my time to ensure the contacts were cleaned off completely and the copper was showing in each. The one thing I noticed is when your reinstalling
the ecu back into the kick panel you have to be very cautious not to binde up the cord because it will shift the chip which will not work properly. I used duck tape
to secure the cord and put pressure on it to prevent the cord from moving.
Hope this helps some
SNK3BTE04 is offline   Reply With Quote
Old 05-04-2012, 12:10 PM   #12
Yeah but I told them they can either return it for me or lose my business. They returned it.
---------- Post added at 01:10 PM ---------- Previous post was at 01:07 PM ----------
I've found out that most places say they can't do certain things. They can, they just don't want to. Plus if it makes your car shut off, that would be a nasty law suit if someone got hurt.
Old 05-08-2012, 07:00 AM   #13
Randl114's Avatar
Re: new tuner isues
Here is where I stand a few days later to think about it... Car still won't strat. I checked the fuel pump relay and it is fine. The pump is ok. I removed the chip from the computer and the car still won't start. Now with no chip when I put the key to the on position a light on the dash flashes security. Is there a relearn procedure that anybody knows about.
Old 05-08-2012, 10:45 AM   #14
Arron's racecar's Avatar
Region: Nevada
Now that the chip is removed you could disconnect the battery for like 15-20 seconds and try it again. this should reset the computer to its factory 1st start parameters.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 05-08-2012, 11:06 AM   #15
Randl114's Avatar
Re: new tuner isues
I might have found the issue. Anybody have trouble running the control cable to the chip in the computer? It seems like there is no room. Or do I plug it in, turn the knob to the setting I want, then take it back out. Been searching for a good way to run the cable but it seems like the plastic housing for the computer is solid at the top where the cable should go.
11:05 PM
