under pullie good or bad? - Mustang Evolution
Old 05-04-2012, 01:23 PM   #1
scottiep101's Avatar
scottiep101 is offline   Reply With Quote
Old 05-04-2012, 01:33 PM   #2
Under driver pullies are a great thing to have.
96gt014.6 is offline   Reply With Quote
Old 05-04-2012, 01:36 PM   #3
What exactly do they do, what's the benefit?
Old 05-04-2012, 02:05 PM   #4
Re: under pullie good or bad?
they do help a little bit (5-8hp perhaps), maybe a SLIGHTLY bit better MPG. The issue is they underspin everything so the alternator may not fully charge at idle~ most dont have a huge issue unless they idle the car a lot or have a stereo system.
Old 05-04-2012, 03:04 PM   #5
Cantlin01's Avatar
Is it gonna kill my battery at idle?
Cantlin01 is offline   Reply With Quote
Old 05-04-2012, 03:13 PM   #6
Arron's racecar's Avatar
Region: Nevada
I have bbk UDPs on my car and have never had any issues. Note that I also have 2 kicker 900w amps powering 2 kicker c12 competition subs.
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 05-04-2012, 04:19 PM   #7
What gains did you notice?
Old 05-04-2012, 06:01 PM   #8
Region: Nevada
As was said earlier it's really only 8-10HP maybe more with a tune. but it's not really adding HP so much as simply freeing up HP.
Old 05-04-2012, 08:21 PM   #9
2002VertGT's Avatar
+1, although I believe its more around 5-8 hp freed....but none the less, get some but only get SFI certified bolt on pullies, DO NOT GET the piggy back style...
4.10 Gear/RPM thread
Old 05-04-2012, 08:36 PM   #10
DaBluedude's Avatar
Ill play devils advocate. I don't like them. Its a very slight advantage for a significant risk to your belt system. I prefer to keep the stock pulleys.
2003 Mach 1
Old 05-04-2012, 09:06 PM   #11
2002VertGT's Avatar
I just don't see Steeda releasing a product with their name on it if it was a significant risk to your motor...
Old 05-05-2012, 06:39 PM   #12
Mile high JDF's Avatar
I don't see any real benefit from them. I have a buddy who bought his car with them on and he's blown 1 alternator and 3 alternator wiring harnesses because of them
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-05-2012, 08:27 PM   #13
2002VertGT's Avatar
Can you prove it was the UDP? And not faulty equip or overload from a system drawing too much? Many many more people have had them with absolutely no issues...
Old 05-05-2012, 08:37 PM   #14
McNassty's Avatar
Love em, never had trouble. Don't know about HP gains but definitely improved throttle response
McNassty is offline   Reply With Quote
Old 05-05-2012, 09:48 PM   #15
His car is bone stock other than gears, the UDPs, and a short throw. It ran like a top up until that point, I can't give you a 100% positive answer but I'm 98% certain those are it. He's got a 95 GT by the way
Old 05-05-2012, 10:08 PM   #16
2002VertGT's Avatar
That's wierd, I mean different cars take to mods differently....I will be using stock alt pulley...and eventually getting a high amp alt...
Old 05-05-2012, 10:28 PM   #17
Yeah it's been a real stumper for us. Gonna try and switch everything out here in the next couple of weeks. I could watch his headlights dim at idle because his alternator just wasn't able to put out enough voltage at idle.
Old 05-05-2012, 11:28 PM   #18
2002VertGT's Avatar
Did he use the ud alt pulley or the stock?
Old 05-05-2012, 11:46 PM   #19
That happened with the UD pulley
Old 05-06-2012, 12:01 AM   #20
2002VertGT's Avatar
I'll be using stock alt pulley and ud crank and water pulley
Old 05-06-2012, 12:42 PM   #21
Good idea
Old 05-07-2012, 10:21 PM   #22
wolfstang03's Avatar
I got my Bbk piggyback ud pullies super cheap so if figured why not!? Didn't notice anything really.. not to mention I did my tb and plenium at the same time! They look cool and shiny too!
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 05-07-2012, 10:31 PM   #23
Eturner's Avatar
I've got UD Pulleys on my '04 GT!.. Alt., Water, and crank pulleys!.. Noticed a little bit better throttle response and all!... Never had a problem with them either!..
Old 05-08-2012, 06:18 AM   #24
jjsg09's Avatar
I have the Steeda UD and I noticed a bit more I the throttle. I do have a tune so that may make the difference. I did have the stock pulley on the alt and my battery died within a months time. Charged the battery and it did it again. Swapped the steeda alt pulley on and didn't have a problem since.
08:15 PM
