Lights - Mustang Evolution
Old 05-07-2012, 05:35 AM   #1
Snapple750's Avatar
Lights
I can't tell what happened to my headlight lenses. They don't look scratched. What do you guys think happened?
ID:	49493   Click image for larger version
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 05-07-2012, 05:36 AM   #2
xhgwx's Avatar
Same with mine.
It's a build up on the inside of the headlight that when taken apart can easily be wiped off.
xhgwx is offline   Reply With Quote
Old 05-07-2012, 06:22 AM   #3
Las0mbra's Avatar
No, not at all what he said, that's the clearcoat peeling off. Look up how to sand down headlights then spray a nice new coat of clearcoat on them.
Old 05-07-2012, 07:08 AM   #4
xhgwx's Avatar
Oh mine had like water build up on the inside i just wiped mine. Looks fine mow
Old 05-07-2012, 07:44 AM   #5
Re: Lights
I agree, look it up and you will see how to do it but if you go to a local parts store like say auto zone, etc you will find that turtle wax, 3m, etc has a kit already made up with everything to need to do it with. Its called headlight restore made my turtle wax, it works dont get me wrong but on yours might take two kits per head light esp the right side. FYI, dont get the kit that does it on the drill, you will be sorry later only get the kit that allows you to do it by hand just a opinion though. It worked for me at least, good luck.
southernstang00 is offline   Reply With Quote
Old 05-07-2012, 09:02 PM   #6
Snapple750's Avatar
Thanks for the help guys
2 Legit 2 Quit
Old 05-08-2012, 05:53 AM   #7
wolfstang03's Avatar
My lights are starting to peel too. Not as bad as yours but still drives me nuts!
--WOLFSTANG 03--
wolfstang03 is offline   Reply With Quote
Old 05-08-2012, 09:19 AM   #8
Re: Lights
on the 98 cobra I bought they were doing the same thing but instead of sanding and etc it gave me a reason to buy the smoke headlights
Old 05-08-2012, 02:10 PM   #9
Las0mbra's Avatar
Me too! I bought some new ones. Black housing and clear side markers for $80 off eBay
Old 05-08-2012, 07:15 PM   #10
Snapple750's Avatar
I didn't even know there was a clear coat on head lights.
2 Legit 2 Quit
Old 05-08-2012, 08:16 PM   #11
kelidd's Avatar
Mine was doing the same thing when I bought her.I ended up using a 3m kit And bought some extra 800 and 1k grit sandpaper it took me about an hour for each lens but they turned out good . Just pull them out of the car when you do them and when you are finished give then a good waxing and it will last a while.
kelidd is offline   Reply With Quote
Old 05-08-2012, 10:48 PM   #12
Re: Lights
there go, good advice...
02:46 AM
