Can you test key? - Mustang Evolution
Old 05-07-2012, 06:43 AM   #1
Csnow99gt's Avatar
Can you test key?
WHen I try to start my stang it locks and unlocks the doors, and turns alarm off and on! And now alarm is stuck on and will not allow car to start!? Any help is greatly appreciated!!
Csnow99gt is offline   Reply With Quote
Old 05-07-2012, 07:33 AM   #2
Re: Can you test key?
okie, try cycling the key in the door lock back in forth like three or more times. If this doesnt fix your problem then try a spare key if you got one, both in the doors and ignition. If both keys dont work then chances are it isnt the key its the anti-theft module, which more then likely you will have to bring it to ford or a shop that can program the module or at least thats what happen to mine but I had the speed shop disable it though. hope that helps...
southernstang00 is offline   Reply With Quote
08:10 AM
