Trunk wont pop open - Mustang Evolution
Old 05-07-2012, 12:30 PM   #1
CodyNelson's Avatar
Region: West Virgina
Trunk wont pop open
Hey guys, This weekend I went to get into my trunk and the button wouldnt work. I checked all my fuses and everything is as it should be. If I sit in the driver seat and push the button I can hear a click under the dash. Also the button in the glove box doesnt work either. I can open it with the key and the emergency release on the inside works too. Any suggestions??
Old 05-07-2012, 01:10 PM   #2
meano1's Avatar
Does your remote lock/unlock work?
1998 Mustang Gt, MSD coils, Ford Racing lowering springs, KYB shocks, caster camber plates, Flow Tech exhaust, K&N CAI, auto trans with shift kit, Jet Performance module, full length sub frame connectors, Redline Tuning hood struts. Oh yea, forgot to mention the Plasti Dip stripes.
meano1 is offline   Reply With Quote
Old 05-08-2012, 12:04 AM   #3
Vegas97gt's Avatar
Region: Nevada
Possibly the trunk lock actuator pull the connector out and hook up power directly to it see if that's the problem
Vegas97gt is offline   Reply With Quote
Old 05-08-2012, 06:08 AM   #4
jjsg09's Avatar
Clean where it latches and maybe use some WD40 on it. It might be hung up on dirt and junk that has gotten in there. Or you supercharger has scared it shut! LOL!
Old 05-09-2012, 06:14 AM   #5
CodyNelson's Avatar
Re: Trunk wont pop open
Forgive me for sounding like an idiot, but how would i do that?
---------- Post added at 08:14 AM ---------- Previous post was at 08:13 AM ----------
I wish that was it!
Old 05-10-2012, 02:19 PM   #6
Vegas97gt's Avatar
Region: Nevada
I will pull apart mine tonight and try to give you a step by step
Old 05-11-2012, 07:19 AM   #7
CodyNelson's Avatar
Okay thanks
Old 05-11-2012, 06:19 PM   #8
Vegas97gt's Avatar
Region: Nevada
Ok so I haven't been able to take mine apart I have been busy with work but I managed to snag a pic of a trunk latch actuator from work on a 08 Saleen it will give you an idea though of what it looks like and just hook a wire up to the positive and negative of a battery, jump box or a car charger to give it 12 volts and pull the connector out and touch each wire to one of the plugs on the actuator and it should pop if not its bad.
04:37 AM
