exhaust popping - Mustang Evolution
Old 05-07-2012, 05:47 PM   #1
1shotkllz's Avatar
exhaust popping
Anyone have problems with a popping sound from your exhaust? My idle goes down a little, then my exhaust pops and my idle goes back to being regular. Any suggestions?
1shotkllz is offline   Reply With Quote
Old 05-07-2012, 05:51 PM   #2
Supe01stang's Avatar
Sounds like back pressure.
Supe01stang is offline   Reply With Quote
Old 05-07-2012, 05:53 PM   #3
JetWolf's Avatar
Send a message via Skype™ to JetWolf
Ha, mine does that to after I run him hard, normal for me though.
2006 JetWolf Gilbert, AZ. Come race me, I dare you. ASU!
JetWolf is offline   Reply With Quote
Old 05-07-2012, 06:00 PM   #4
I have a similar problem ... Well not really a problem yet until I get a sct tuner. I had my exhaust redone 3 weeks ago. At idle my rpm is 700-750 regular and when I Stop at a light my rpm drop to 500 for 2-5 seconds like it's going to shut off but I doesn't. I think the sct tuner will help me here. Let's see. Same problem I think without the popping sound.
Old 05-07-2012, 06:04 PM   #5
1shotkllz's Avatar
Yeah my idle does the same exact thing, except that when its starting to idle back up it pops? No CE light or anything
Old 05-07-2012, 06:21 PM   #6
taylor98gt's Avatar
Mine does that too, I think its the IAC valve, I'm changing mine tomorrow ill let you all know if it helps.
taylor98gt is offline   Reply With Quote
Old 05-07-2012, 06:23 PM   #7
1shotkllz's Avatar
I replaced my iac a few weeks ago when i installed my cai
Old 05-07-2012, 07:49 PM   #8
taylor98gt's Avatar
What was yours doing.before you replaced it?
Old 05-07-2012, 07:52 PM   #9
1shotkllz's Avatar
Same thing, popping. As well as idle going up and down
Old 05-07-2012, 08:23 PM   #10
taylor98gt's Avatar
Okay, I ordered mine tonite it'll be here at 1 tomorrow.
Old 05-07-2012, 08:39 PM   #11
1shotkllz's Avatar
Cool, let me know how it turns out. Im thinking a possible vac leak somewhere? I don't think its a missfire or anything cause when my mazda had problems with that its like i was running into a wall with the car bucking, and jumping.
Old 05-07-2012, 08:47 PM   #12
Lorraine's driver
ab_mach1's Avatar
Mine will do like a one pop or two pop occasionally when idling. I haven't noticed any RPM changes when this happens.
Instagram: @ab_mach1
Old 05-10-2012, 04:56 PM   #13
LAS97GT's Avatar
Never had the problem like its said here but I am curious to find out the problem and solution.
---Las97GT
Old 05-10-2012, 08:50 PM   #14
2002VertGT's Avatar
If you are running rich excess fuel in the exhaust can ignite and cause a pop...but that wouldn't explain the idle issue..
4.10 Gear/RPM thread
Old 05-10-2012, 08:56 PM   #15
1shotkllz's Avatar
Yeah i knew about the fuel, always use regular octane 87
Old 05-10-2012, 09:44 PM   #16
2002VertGT's Avatar
If u r running without cats or without exhaust you will hear it even with 87....but that still doesn't explain the idle
Old 05-10-2012, 10:23 PM   #17
1shotkllz's Avatar
I've been chasing this idle hunt for awhile now. Honestly have no idea where to even start now lol
Old 05-10-2012, 10:27 PM   #18
Lorraine's driver
ab_mach1's Avatar
Make sure you don't have any leaks in your cold air setup after the mass airflow sensor. My buddies truck idled up and down and he wound a leak in his stock setup. Probably from off-roading.
Old 05-10-2012, 10:46 PM   #19
1shotkllz's Avatar
Got a cai, no leaks or anything. Already checked that
Old 05-10-2012, 10:48 PM   #20
Lorraine's driver
ab_mach1's Avatar
MAF seems clean? Also, did it start doing this after removing the factory screen? Apologies if you've done this already.
Old 05-10-2012, 10:54 PM   #21
1shotkllz's Avatar
Yeah maf is clean, and it was doing this before. Its cool, bro. Is it possibly air temp sensor on the intake?
Old 05-10-2012, 11:05 PM   #22
Lorraine's driver
ab_mach1's Avatar
Could be that and maybe affecting EGR. Do you have EGR delete? Dunno what kinda symptoms that would have exactly.
Old 05-10-2012, 11:07 PM   #23
1shotkllz's Avatar
I was reading up on the EGR yesterday, and don't i have to have a tuner to turn it off?
Old 05-10-2012, 11:09 PM   #24
Lorraine's driver
ab_mach1's Avatar
Your idle is affected, how about when you accelerate?
Old 05-10-2012, 11:17 PM   #25
1shotkllz's Avatar
I know if i get into it kind of hard then have to come to a stop it usually almost stalls out if not completely. Sometimes it stalls out 3 or 4 times in a row until it finally idles
Old 05-10-2012, 11:22 PM   #26
Lorraine's driver
ab_mach1's Avatar
I'd check the fuel filter, then maybe spark plugs. Does it smell like gas when it's doing this above ^?
Old 05-10-2012, 11:25 PM   #27
1shotkllz's Avatar
Nah no gas smell, i thought about that and checking the cops as well
Old 05-10-2012, 11:33 PM   #28
Lorraine's driver
ab_mach1's Avatar
Yup on COPs. Watch them dang connectors. I broke the lil part that clicks and it would stay connected. Luckily it would stay connected when I put the COP all the way in place. Dunno if you can buy new harness or not. Gotta be something simple. Seems like it the chasing part that's hard on this stuff.
---------- Post added at 01:33 AM ---------- Previous post was at 01:28 AM ----------
Also, check PCV valve, make sure not to replace with cheapo brand.
Old 05-10-2012, 11:59 PM   #29
1shotkllz's Avatar
I'm just hoping its nothing expensive. My luck its something simple i should of looked at first. Same case with my mazda, replaced everything that caused a missfire until i was told the coil pack was bad. i got tired of chasing that gremlin
exhaust
02:37 PM
