c clamps - Mustang Evolution
Old 05-09-2012, 08:28 PM   #1
Venemous02GT's Avatar
c clamps
How do you get the c clamps out on an 02 mustang gt?
---------- Post added at 10:28 PM ---------- Previous post was at 10:24 PM ----------
Clips**
Venemous02GT is offline   Reply With Quote
Old 05-10-2012, 07:15 AM   #2
jjsg09's Avatar
Your talking about the rearend right?
Old 05-10-2012, 08:47 AM   #3
Yes
Old 05-10-2012, 09:59 AM   #4
How and where do I count the splines? I need to figure out whether it has 28 or 31 splines.
Old 05-10-2012, 10:51 AM   #5
Re: c clamps
i think you have to take the pin that goes through the differential case out then slide the axles in a bit and then you can pop them off.
Old 05-10-2012, 10:53 AM   #6
You have to pull an axle to count splines. If your rear is stock its 28 spline.
To remove c clips you have to drain the diff, remove the diff cover, locate.c.clip on either side of the locker and remove.
Old 05-10-2012, 11:07 AM   #7
I believe it is stock. Is there a way other than using two screwdrivers that will work?
Old 05-10-2012, 10:49 PM   #8
Mile high JDF's Avatar
Magnet tool, should pull right out assuming you pulled the center pin out.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-11-2012, 08:45 AM   #9
We got em out, we had to remove the abs sensors, which break easily.
---------- Post added at 10:45 AM ---------- Previous post was at 10:43 AM ----------
I'll have a whole new rear end by the end of tomorrow, (except gears), new axles, new bearings, carrier bearing and everything.
12:32 PM
