Front upper A arms replacment - Mustang Evolution
Old 05-10-2012, 03:50 AM   #1
Ahmed ali khan's Avatar
HEllo everyone want to replace my upper A arms
Which is the best brand to go for
Please help me in this thanks
Ahmed ali khan is offline   Reply With Quote
Old 05-10-2012, 06:07 AM   #2
jjsg09's Avatar
The 99-04 mustangs don't have upper A arms. Do you mean the lower A arm?
Old 05-10-2012, 08:56 AM   #3
Thanku so much for the info i
R u sure abt this that there are no upr A arms in 99-04 Gt please conform me
Old 05-10-2012, 09:04 AM   #4
runvsofthisbull's Avatar
Re: Front upper A arms replacment
Well you could get the 03-04 Cobra A arms or if you want to go aftermarket Check out PA Performance or Maximum Motorsports. I can't look on MM's website right now (at work), but I believe that you have to use their K-member/coil over kit to utilize their arms....but don't quote me on that. I chose PA performance K-member and A arms as I did not want to go to a coil-over style set up yet ($$$). I think QA1 is a good brand too.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 05-10-2012, 01:09 PM   #5
Pa performance k member does it work with kyb shocks or with stock shocks?
Old 05-10-2012, 02:05 PM   #6
I don't see why not. If you KYB fit the stock K-member then I would assume the same for the PA. I'm using Tokico Shocks in the PA performance K member and a arms and they fit fine.
Old 05-10-2012, 02:21 PM   #7
some aftermarket K-Members come setup for coil over's and will not work with the factory style shocks
Old 05-10-2012, 02:54 PM   #8
+1, thus why i went with PA over MM since they only off K-members with coil over conversions.
Old 05-10-2012, 03:47 PM   #9
Can u send me da part number of your k member, which you have in your car please
I hope it fits direct bolt in
And i will run bolton 4.6l stock on dat k member and then will buy kb
So dude send me the part number so i can order
Old 05-10-2012, 04:59 PM   #10
Well first of all why are you replacing your a arms? If your car is a DD then you probably would be fine without replacing them completely. My car was a 3.8L therefore while I'm swapping it in place with a 4.6 it required the k member, but yours does not so I don't really see the point right now. Anyway there are differences in their k members and A-arms. First off you need to decide if you want Chrommoly. Typically its stronger, however again if its a DD mild steel will be just fine in my opinion and in PA's. Just go to the site and order from this link.
PA Racing
11:40 PM
