Adding an amp and sub - Mustang Evolution
Old 05-10-2012, 08:10 AM   #1
02utahgt's Avatar
Region: Utah
Is it possible to add an amp and sub to a stock sound system?
02utahgt is offline   Reply With Quote
Old 05-10-2012, 08:36 AM   #2
Snapple750's Avatar
Yes, you either need an amp with speaker level inputs, or a high level to low level converter. Do you have the Mach 460?
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 05-10-2012, 08:47 AM   #3
stangdude512's Avatar
Dude if u have a 100 bucks I would go to walmart an get this package they have it gives u a pioneer radio with two 6 inch door speakers an the two 6 by 9s for the bak very easy to install an I know its from Walmart but they sound an work great I got my two 12 inch kickers an amp in my trunk wouldn't ask for anything else
stangdude512 is offline   Reply With Quote
Old 05-10-2012, 09:00 AM   #4
02utahgt's Avatar
Region: Utah
Yes I have the 460
Old 05-10-2012, 09:10 AM   #5
02PONY's Avatar
Yes u can , this is what I did.
there is a free/very cheap mod thread on here somewhere
02PONY is offline   Reply With Quote
Old 05-12-2012, 05:24 PM   #6
robvandam's Avatar
Re: Adding an amp and sub
Its really easy. You basically use the stock speaker wires as the input to the amp. You can buy a kit for this that makes it look really clean.
"They that can give up essential liberty to obtain a
little temporary safety deserve neither liberty nor safety." -Ben Franklin
The democracy will cease to exist when you take away from those who are willing to work and give to those who are not. - Thomas Jefferson
robvandam is offline   Reply With Quote
Old 05-13-2012, 06:54 AM   #7
Snapple750's Avatar
If you use the factory Mach amps, you'll also have a +12 volt source for the rem as well.
On the passenger side factory Mach amp, disconnect the 3 wire socket (directed away from cabin)
Using the tap and runs(or you can splice them), run speaker wire from the three wires to the amp.
The grey one is the rem wire, the blue/red one is the speaker level positive signal, and the green/black is the negative signal.
Using an RCA cable, strip the rubber off and separate the bare wires from the wire in the center. Twist the bare wires together and connect the wire from the green/black to it. Strip the center wire, then twist and connect it to the wire from the red/blue. Then connect the RCA to the amp
---------- Post added at 08:54 AM ---------- Previous post was at 08:52 AM ----------
And make sure to insulate all of your copper showing with electricians tape.
2 Legit 2 Quit
Old 05-13-2012, 03:08 PM   #8
AgentOrange's Avatar
^ A trip to Harbor Freight can net you all the little stuff for this super cheap. I prefer the heat-shrink wire insulation over tape.
AgentOrange is offline   Reply With Quote
10:17 AM
