Gears - Mustang Evolution
Old 05-12-2012, 07:04 AM   #1
Venemous02GT's Avatar
Gears
Will 3.31 gears from an '09 mustang V6 work for a 02 Gt? Does it matter if the v6 has a different axle size when it comes to gears?
Venemous02GT is offline   Reply With Quote
Old 05-12-2012, 08:12 AM   #2
2002VertGT's Avatar
If the axle is not a 8.8 do not try to put it in your car...also, 3.31 will most likely not even be any notice to you from your 3.27...
4.10 Gear/RPM thread
Old 05-12-2012, 10:01 AM   #3
Nevermind it was a gt so it was an 8.8 axle. It won't be much different than the 3.31's performance wise, however the bearings on the stock ones were ruined.
Old 05-12-2012, 12:48 PM   #4
What are the stock size shims for an 02 mustang gt with 3.27 gears? What size would work best for 3.31 gears?
Old 05-12-2012, 01:07 PM   #5
2002VertGT's Avatar
Are you paying for the 3.31 gears? What's your reasoning for switching to them?
Old 05-12-2012, 03:19 PM   #6
I got them from a friend and didn't pay for them. Mine were damaged when my pinion bearing was damaged.
Old 05-12-2012, 03:36 PM   #7
2002VertGT's Avatar
Oh ok..if you go to jegs I've been told you can order them from there for any gear.
Old 05-12-2012, 09:21 PM   #8
Lorraine's driver
ab_mach1's Avatar
+1 http://www.jegs.com/i/Ford+Racing/397/M-4700-B/10002/-1
Instagram: @ab_mach1
Old 05-12-2012, 09:23 PM   #9
Re: Gears
You have to get someone with experience to setup the shims/backlash/play on the gears. Otherwise you will have premature wear and failure and be right back in the same boat.
Every set of gears and every housing is different as far as what they require.
Old 05-13-2012, 12:07 AM   #10
Mile high JDF's Avatar
+1 you can try and re-use the shims that come out but you are really testing your luck. If you buy a rebuild kit then it will come with new shims.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-13-2012, 04:13 AM   #11
32vNomad's Avatar
Re: Gears
I beleive american muscle is having a sale on gears.
32vNomad is offline   Reply With Quote
02:38 AM
