IAC restrictor plates - Mustang Evolution
Old 05-12-2012, 11:50 PM   #1
Lorraine's driver
ab_mach1's Avatar
I just now heard of these. They are supposed to return the engine to idle faster. Why would this be good? Seems like this would be bad if you had a 5spd when your jammin through the gears.
Instagram: @ab_mach1
Old 05-13-2012, 03:09 PM   #2
AgentOrange's Avatar
Depends on how you drive. A higher idle make it easier to take off easy without gassing, and I usually heel-toe when I downshift to be easy on the clutch. A higher idle makes that easier as well. I do see your point though, I find it to be a preferential thing.
AgentOrange is offline   Reply With Quote
03:59 AM
