Clutch install prices? - Mustang Evolution
Old 05-13-2012, 07:28 PM   #1
mcvicar04's Avatar
Hey guys coming up on the time to install my clutch have you guys had yours installed my a shop or did you do it your self any thought or input is appreciated
mcvicar04 is offline   Reply With Quote
Old 05-13-2012, 10:46 PM   #2
Vegas97gt's Avatar
Region: Nevada
Did it my self took about 4 hours on a Saturday not super difficult but you only want to do it once so replace your throw out bearing pilot bearing clutch fork pressure plate clutch disk and have you flywheel machined or replaced
Vegas97gt is offline   Reply With Quote
Old 05-14-2012, 04:29 AM   #3
t0t4lbl4ck0ut's Avatar
It will take Much longer then 4 hours if you have long tube headers. Your transmission will NOT clear long tubes width wise anywhere so you have 2 options. Unbolt the headers from the heads and spread them out or cut the bastards and weld them back up. I took the easiest of the 2 and cut em and it still had clearance problems. Like he said, do it ALL at the same time. It's a pain and you won't wanna do it again do get it right the first time. I'd suggest changing your quadrant too if you haven't already. The added clutch strength will possibly break it. Just a good safety measure.
t0t4lbl4ck0ut is offline   Reply With Quote
Old 05-14-2012, 07:24 AM   #4
Codysmustang's Avatar
Re: Clutch install prices?
i agree with them, i did it myself as well and since mine had no mid pipe i had to cut my pipes off to get the tranny down.. and yeah you won't want to do any of this again for a long while so get everything fixed up. and if got long tubes and try to bring it places to do it they will charge some outrageous price to get it all done.. id just set a day to do it and get it done.
Codysmustang is offline   Reply With Quote
Old 05-14-2012, 04:40 PM   #5
mcvicar04's Avatar
I have a stock exhaust and will be putting an bbk off road X pipe on when I finish I also have the ford racing throw out bearing an pilot bearing with a new 6 bolt flywheel and exedy stage 2 clutch with a new quaderent I have the firewall adjuster but the adjustable clutch cable was a pain in the *** I will buy a non adjustable one
It's my daily driver and I just don't want it up on jacks for a week if I mess up or something
Old 05-14-2012, 09:46 PM   #6
Vegas97gt's Avatar
Region: Nevada
Oh ok well when you do your clutch it will be a good time to switch to your x pipe and it won't take you a week but just a hint go to an auto zone or harbor freight and buy or rent a pilot bearing puller that will strand you if you can't get it out and it is a need to replace but other than that it should just be a Saturday type deal
Old 05-14-2012, 10:47 PM   #7
Here's a even better suggestion. Take 2 pieces of bread. Yes BREAD and cram them in the hole then take a socket just big enough to fit in the hole and hammer it in and it will pop out. It sounds ridiculous but it seriously works.
Old 05-15-2012, 04:32 AM   #8
br10301's Avatar
I just had my clutch done for 500 in labor not including parts
br10301 is offline   Reply With Quote
Old 05-15-2012, 05:17 AM   #9
deadsp0t's Avatar
Grease and a wooden dow rod work as well.
Used to have clutches replaced for $150 labor. Replaced auto's for less then $200 too.
That's unimpressive
Old 05-15-2012, 01:32 PM   #10
Breads less mess lol
Old 05-16-2012, 02:49 PM   #11
LAS97GT's Avatar
About the clutch cable. I bought the Steeda model with the quadrant. Tossed the stock. Adjusting is a breeze and don't have to go under car to adjust. Clutch is heavier though.
---Las97GT
Old 05-16-2012, 05:38 PM   #12
mcvicar04's Avatar
With the AM one the 2 nuts wouldn't stay locked and then the cable exploded in the firewall.... I'm just Gona do stop
Old 05-17-2012, 03:47 AM   #13
Dksnb's Avatar
I had a stage 2 Kevlar zoom clutch and 6 bolt aluminum flywheel replaced for 900. Thats parts and labor along with having long tube headers and a offroad H pipe
Dksnb is offline   Reply With Quote
Old 05-17-2012, 08:43 PM   #14
mcvicar04's Avatar
I just went to my local shop kaspers on college drive in blackwood NJ and they told me 350 for complete install and doing my pipe
---------- Post added at 02:43 AM ---------- Previous post was at 02:42 AM ----------
My XPipe*
Old 05-17-2012, 09:03 PM   #15
Mmustang01's Avatar
+1
01 gt
Procharger d1
Mmr long block
480 rwhp 450 # of torque
Mmustang01 is offline   Reply With Quote
Old 05-18-2012, 03:17 PM   #16
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
i had mine replaced about 3yrs ago. clutch fork,throw out bearing, pilot bearing, pivot ball joint, and clutch assembly for around 600.,
SaturnMan8227 is offline   Reply With Quote
Old 05-18-2012, 03:46 PM   #17
mcvicar04's Avatar
That's about where I'm at but my clutch flywheel and acc. Was about 350, then 350 labor
Old 05-22-2012, 08:37 PM   #18
mcvicar04's Avatar
So I am picking her up tomorrow it got pushed back a day... But they charged me 100 more bucks to install the adjustable clutch cable... Kinda upset about that but I know it's worth it lol
Old 05-22-2012, 11:22 PM   #19
Vegas97gt's Avatar
Region: Nevada
Holy crap since they did that make sure it's perfect if anything is wrong say it before you leave an they try and say you broke it
Old 05-23-2012, 07:54 AM   #20
mcvicar04's Avatar
Yea I'm Gona be picky lol
Old 05-23-2012, 11:05 AM   #21
mcvicar04's Avatar
So I picked it up and I was 444$ 350 for install of clutch flywheel TOB an pilot bearing then only 65 for adjustable clutch cable then tax I'll be posting a video later
Old 05-23-2012, 06:16 PM   #22
Cervantes107's Avatar
I did mine myself on jack stands, it was hard but not impossible, I dont have much experience working on cars either
Cervantes107 is offline   Reply With Quote
02:41 PM
