05-14-2012, 05:57 PM
#1 | | Registered User
| Ported vs tfs
Would the twisted wedge heads yield as much power as ported pi heads
2 Legit 2 Quit
05-14-2012, 06:00 PM
#2 | | Registered User
More I'm sure...
2001 Ranger Edge 4x4 xcab (sold to cousin) 4.10 Gear/RPM thread |
05-14-2012, 07:08 PM
#3 | | Registered User
| Re: Ported vs tfs
More by far. There is a reason that they cost so much money.
05-14-2012, 07:10 PM
#4 | | Registered User
Reports with dyno sheets showing tfs heads reaching 330-360 hp
05-14-2012, 10:35 PM
#5 | | Registered User
| Re: Ported vs tfs Quote:
Originally Posted by 2002VertGT Reports with dyno sheets showing tfs heads reaching 330-360 hp | +1
Amazing power for an N.A 2V.
05-15-2012, 02:38 AM
#6 | | Registered User
Ported pi heads only flow about 250 cfm at a stage 3 port which is about as big as it gets. Tfs heads flow nearly 260 out of the box before porting and on top of that with the way the valves are placed you can run a super massive lift cam and not worry about clearance.
05-16-2012, 03:35 PM
#7 | | Registered User
| Quote: |
Originally Posted by 2002VertGT Reports with dyno sheets showing tfs heads reaching 330-360 hp | Know which they were? I think there's 2 types for NA. I've been eying them.
---Las97GT
05-16-2012, 08:47 PM
#8 | | Registered User
| Quote: |
Originally Posted by LAS97GT
Know which they were? I think there's 2 types for NA. I've been eying them. | No I don't, sorry..
05-17-2012, 07:28 PM
#9 | | Registered User
If you are staying NA get the 38cc ones. They will bump up your compression to around 10.3:1. If you plan to go FI then get the 44cc set
05-21-2012, 05:13 PM
#10 | | Registered User
| Quote: |
Originally Posted by CodyNelson If you are staying NA get the 38cc ones. They will bump up your compression to around 10.3:1. If you plan to go FI then get the 44cc set | Can I use 44cc as NA then go FI ltr or FI have to FI right away? I'd like to keep my options open. Lots a $ for tfs
---Las97GT
05-21-2012, 07:37 PM
#11 | | Registered User
| Re: Ported vs tfs
the 44cc heads keep your compression stock(if your on stock shortblock) and the 38cc heads bump your compression about to around 10:5 like stated above..(if your on stock shortblock)
also some correction trickflow heads out the box flow 242 on the intake and 203 on the exhaust..that is at 600 lift...
05-22-2012, 03:31 PM
#12 | | Registered User
| Quote: |
Can I use 44cc as NA then go FI ltr or FI have to FI right away? I'd like to keep my options open. Lots a $ for tfs | 44cc will work wonderful on stock if you plan to go FI down the road. Just get some forged internals
06-14-2012, 04:02 PM
#13 | | Registered User
| Quote: |
44cc will work wonderful on stock if you plan to go FI down the road. Just get some forged internals | Thanks!! That's fits my plan. Take a look. I want to build 350-400 NA. It's going to be a challenge, but I have plans already. Thanks again.
---Las97GT
06-14-2012, 10:51 PM
#14 | | Registered User
| Re: Ported vs tfs
Stock 02 GT motor. stock Comp 9.6-9.8:1
44cc TF heads-9.4:1
38cc TF heads-10.2:1
I wouldn't hesitate to run Boost on either of those ratios...just make sure the tune is good and 93 octane is a available.
Also for those wondering...
96-98 NPI shortblocks with stock heads-9.6-9.8:1 como
44cc TF heads-10:1
38cc TF heads-11:1
PI Heads-10.3
And on 03-up 32v shortblocks (mach 1, Avaitor, Marauder) 10.1:1
TF 44cc-11.4:1
TF 38cc-12.7:1
PI heads-11.8:1
Teksid Shortblocks...(mark Vii, 99/01 Cobra, 96-98 Cobra)-9.6-9.8:1
TF 44cc-10.8:1
TF 38cc-11.9:1
PI heads-11.1:1
HOpe this helps. You can mix and match some good bottom ends with PI/TF heads and get some good compression to suit whatever you want to do. Good luck!
89 Coupe-Carbd 32v, 437rwhp NA, 592rwhp Spray
79 Coupe-Project IRS, 32v, AC Daily Driver
01 Bullitt-B cammed 32v (wifes)
00 Expedition-L swapped, SuperCharged Boat
07 Expedition-stock (wifes), Tow Vehicle
06-15-2012, 08:29 AM
#15 | | Registered User
| Re: Ported vs tfs
Great info!
06-16-2012, 01:34 PM
#16 | | Registered User
+1
---Las97GT
