reverse gear grind - Mustang Evolution
Old 01-18-2008, 07:38 PM   #1
Region: Nevada
reverse gear grind
Just got a new '03 GT and been having issues with the reverse gear. It makes a grinding sound whenever I try to put it in reverse. The only way I been able to get the car to go backwards is to shift it to reverse before I turn on the engine. Anyone know what the problem could be?
chris098 is offline   Reply With Quote
Old 01-18-2008, 08:11 PM   #2
Re: reverse gear grind
Are you having problems in any other gear? It could just be as simple as adjusting your clutch. With the toe of your foot pull the clutch pedal toward you and it might be as easy as that.
Otherwise...it could be a bent fork making it not seat fully into the gear.
Old 01-18-2008, 10:21 PM   #3
MonteCitan's Avatar
Try this next time you start out, put clutch into 4th gear, don't engage of course, just pull shifter into 4th then push back to neutral then pop it back to reverse...
Just about every manual trans I had did the same thing (even if not grinding... then just fighting), putting it in another gear, 4th or 5th first would allow it to go right into reverse on the next shift, I think it has something to do with the synchros and the straight cut gears on reverse...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-19-2008, 09:17 AM   #4
do you have flop in your clutch petel aka to much slack in your clutch cable? That might be an issue.
Old 01-19-2008, 06:31 PM   #5
Region: Nevada
I guess that must of been it. After I put it in 5th I can put it in reverse just fine now. Another question I have, is that a common thing with these cars or is this something I might want to get checked out? Anyway, thanks for the suggestions guys
Old 01-19-2008, 08:56 PM   #6
MonteCitan's Avatar
I've always thought it was common, every stang I've owned, either T5 or tr3650 had done the same thing, reverse isn't sychronized like the forward gears
Old 01-20-2008, 10:39 PM   #7
Scut95's Avatar
Ditto. My 95 sometimes grinds and is usually grouchy going into reverse, especially when its cold outside.
Old 01-21-2008, 09:28 AM   #8
reverse doesnt have synros I dont think~
Old 01-21-2008, 10:49 PM   #9
Scut95's Avatar
I believe you are correct...there really isn't a point to having one either
Rebuilt AOD stalls engine in reverse and only has 1st gear 91StangGT5.0 1979-1995 Mustang GT 5 11-12-2009 05:02 PM
2008 3rd gear grind when cold gotmach Pre-2005 V6 Mustang 16 02-06-2009 08:07 AM
clutch grind ChickStang02 1996-2004 Mustang GT 21 03-24-2007 06:20 AM
How hard to grind off powdercoating on MM sub frames? SpectorV Pre-2005 V6 Mustang 3 05-19-2005 06:20 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 03:41 PM
11:47 PM
