tranny help.. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1996-2004 Mustang GT
Closed Thread
Old 05-16-2012, 08:22 PM   #1
br10301's Avatar
br10301 is unknown around these parts
tranny help..
o I just spent 3100$ on a new king cobra clutch kit and flywheel and a new transmission.. now I picked up my car today and I've put about 30 miles on it and now it's popping out of second on me.. I'm bringing it to the shop tomorrow I just wanna know what you guys think it might be?
br10301 is offline
Old 05-18-2012, 01:15 AM   #2
Vegas97gt's Avatar
Vegas97gt is unknown around these parts
I'm really not to sure any verdict yet and or is it just second or is it almost every gear could it be your clutch not releasing all the way?
Vegas97gt is offline
Old 05-18-2012, 03:02 AM   #3
t0t4lbl4ck0ut's Avatar
t0t4lbl4ck0ut is unknown around these parts
Could be the shifter if it's adjustable. Mine was adjusted to the point where 4th will fully engage but second won't. Just a thought
t0t4lbl4ck0ut is offline
Old 05-18-2012, 09:16 PM   #4
br10301's Avatar
well I found out why it was popping out of second gear.. I was babying it a little too much and not giving it enough rpm's before shifting.. but now its making a whirring noise while I drive and it gets louder the faster I drive.. the machanic said it needs to break in but I think he may be wrong? any suggestions?
br10301 is offline
Old 05-18-2012, 09:25 PM   #5
Azure's Avatar
Azure is unknown around these parts
Does it have an aftermarket short shifter? If so, it may have stops that need to be adjusted. The stops keep you from jamming in gear too hard and hurting the tranny. Not adjusted right and it won't be engaged properly.
---------- Post added at 11:25 PM ---------- Previous post was at 11:22 PM ----------
And if it is a truly "new" tranny you better go easy until the clutch is broken in. Probably some time for the internals, but I'm not sure how long. At least 750 to 1000 before I'd go nuts, if it were me.
Azure is offline
Old 05-18-2012, 10:05 PM   #6
br10301's Avatar
yea it's a brand spanking new tranny, clutch and pressure plate, flywheel, fork, pilot and throw out bearing.. I haven't gone over 2400 rpm yet I put about 100 miles on it so far believe me I'm babying it..
---------- Post added at 11:05 PM ---------- Previous post was at 11:04 PM ----------
I just wish I knew for sure if its the short shifter or not and if it is where I can go to adjust it I mean I bought the car with the short shifter so I have no clue about it
br10301 is offline
Old 05-18-2012, 10:14 PM   #7
Azure's Avatar
I think should be good as far as babying, no clutch dropping! So, pretty sure it has aftermarket shifter? Some models had the stops and the were adjustable. This should be pretty easy to do. To see if you have the, take off the shifter knob and pull the shroud thingy that your shifter boot connect to. Before you do, checkout YouTube for mustang short throw shifter install. There some vids that will help get to where you can see if there is stops on the shifter.
---------- Post added at 12:14 AM ---------- Previous post was at 12:12 AM ----------
Here's an install DIY
http://www.youtube.com/watch?v=JDu0M...e_gdata_player
Azure is offline
Old 05-18-2012, 10:19 PM   #8
Azure's Avatar
The stops might be like on this Steeda Tri ax. The bolt right below the shifter arm stops it from going down to far. I'd draw an arrow to point to it but can't I'm on my phone.
Azure is offline
Old 05-19-2012, 10:49 PM   #9
br10301's Avatar
yea it does but im gonna have it professionally adjusted
br10301 is offline
Old 05-19-2012, 10:52 PM   #10
Azure's Avatar
Totally understand. Especially cause they prolly do it for free since they put the tranny in for you.
Azure is offline
Old 05-20-2012, 12:42 PM   #11
br10301's Avatar
exactly
br10301 is offline
Closed Thread
02:12 AM
