little help needed on adjustable crank gears! - Mustang Evolution
Old 05-17-2012, 07:45 AM   #1
mhobbs's Avatar
so after waiting 2 long months for my custom heads from modular head shop they are here! its a kit. came with cams installed and adjustable cam gears. my invoice paper says, left intake lobe centerline found: 110- install at zero. right intake lobe centerline found: 108 ****** 2. I know I do left first. now like for the right one do I take my one white mark and put it at 108 degrees then move it till the other white mark lines up with the ****** 2 tooth? just making sure im doing this correct. thankyou.
---------- Post added at 08:45 AM ---------- Previous post was at 08:44 AM ----------
adjustable crank gears not cam gears*
mhobbs is offline   Reply With Quote
Old 05-17-2012, 12:38 PM   #2
mhobbs's Avatar
Re: little help needed on adjustable crank gears!
After some research my question is i know one of my white marks needs to be on the ****** 2 position, where is the other white mark suppose to appear? and where should it start? my knowledge is that i put it somewhere then move the cam till the other white line is i just dont know where to put the white link on the cam gear.
09:24 PM
